why does vb not recognise outlook code?
N
ninjaneer
Hi there
I'm still a complete amateur on outlook vba, so please bear with me.
I use Outlook 2003 (that I recieved with a student package of Office) on a
Windows 7 RC PC. I want to create a Macro that formats a mail as html. I
found some example code on the internet, but it gives errors claiming not to
recognize the objects:
"Method or data member not found" in response to
> Application.ActiveInspector.CurrentItem.BodyFormat = olFormatPlain
or "User-defined type not found" in response to >Dim olMail As
Outlook.MailItem
Any ideas on how I can reach my goal to create a Macro that formats a mail
as html or to address the errors?
Thank you for reading my post!
Pieka
Michael Bauer
That sounds like the code isn't running in Outlook but in another
application. There you need to add a reference on Outlook to make its object
model available: Click Tools/References, and add "Microsoft Outlook x
Library".
Also, 'Application' in VBA always refers to the Application of the host
application. For instance, if the code runs in Excel, Application refers to
the root object of Excel, not to the one of Outlook. That is you need to dim
a variable as Outlook.Application, and set it to the right object.
Best regards
Michael Bauer
Am Sun, 21 Feb 2010 05:58:01 -0800 schrieb ninjaneer:
> Hi there
to
> Outlook.MailItem
> Pieka
L Does It Really Work Or Not? Using Outlook 0
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 1
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
Diane Poremsky What does the "J" mean? New Slipstick.com Articles 0
Christiaan Could not complete operation because the service provider does not support it Using Outlook 2
Simon How does the sender/organizer to dictate the color of a meeting invitation. Using Outlook 3
A Does Outlook import Gmail Archive? Using Outlook 1
1Firefly Outlook 2013 Converstation preview does not show my last reply Exchange Server Administration 1
K CommandButton1 does not respond Outlook VBA and Custom Forms 1
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
Alex Hall When updating shared calendar, it does not automatically update personal calendar Using Outlook 3
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
