Variable Attachments in CDO/OL2K7?
C
corquando
Greetings, geniuses.
I have a standard CDO send sub that works just dandy, except for one
small detail.
For each email there will be a variable amount of attachments -
anywhere from 1 to maybe 15 tops.
In the .With statement, I have this (all required statements beforehand
are present. I'm just omitting them here for space's sake.):
'looped for each email sent
With iMsg
Set .Configuration = iConf
> To = EML 'email address from database
> CC = ""
> BCC = ""
> From = "Me@MyMailbox.com"
> Subject = Subj 'defined in the db
> TextBody = strbody 'defined in the db
> AddAttachment (Atch1) 'AHA!! Here's the rub!!
> Send
[\code]
How may I:
a) Loop around the .AddAttachment statement to add the required attachments, or
b) define a variable that would contain the necessary attachment values (Atch1), and have the statement needed only once, and
c) which is best or does it matter?
I've seen solutions for non-CDO programs and earlier OL versions but I'm wary since what I'm doing is different, and spending 2 or 3 hours trying to force something that won't work anyway is demoralizing.
Please ask for whatever additional and needed items I have mindlessly omitted, and thanks in advance!!!
corquando
Michael Bauer
Whereever you get the filenames of the attachments from, loop through it,
for instance with:
for i=1 to count
next
Best regards
Michael Bauer
Am Wed, 24 Feb 2010 22:05:12 +0000 schrieb corquando:
> small detail.
> Code:
> With iMsg
> .To = EML 'email address from database
> .CC = ""
> .BCC = ""
> .From = "Me@MyMailbox.com"
> .Subject = Subj 'defined in the db
> .TextBody = strbody 'defined in the db
> .AddAttachment (Atch1) 'AHA!! Here's the rub!!
> .Send
> End With
> [\code]
> How may I:
attachments, or
C
corquando
'Michael Bauer [MVP - Outlook Wrote:
> ;341979']Whereever you get the filenames of the attachments from, loop
> through it,
> for instance with:
> for i=1 to count
> next
> > Best regards
> Michael Bauer
> Herr Bauer:
> Vielen dank fur die Hilfe . . .
> And it accomplished the attaching quite well. The next issue, though,
> and it should be simple (I just don't know where to look) is to clear
> the Atch1 variable so I don't accumulate attachments on each successive
> send:
> For i = 2 To z
> If Range("A" + CStr(i)) = "" Then GoTo 27
> Subj = Range("C" + CStr(i))
> EML = Range("E" + CStr(i))
> ID = Range("B" + CStr(i))
> Call TextBody(i, strbody)
> y = 0
> With iMsg
> .To = EML
> .CC = ""
> .BCC = ""
> .From = "MyBox@MyAddress.com"
> .Subject = Subj
> .TextBody = strbody
> Do While Range("B" + CStr(i + y)) = ID
> DocName = Range("D" + CStr(i + y))
> Atch1 = "C:\Huge\Medium\Small\" + DocName + ".pdf"
> .AddAttachment (Atch1): y = y + 1
> Loop
> .Send
> End With
> 27 Next
> [\code]
> Each successive email has all the attachments that previous emails have had plus the new ones. I am sure it's an elementary command, but CDO statement catalogs are hard to come by.
> And I know it's simple - I'm good at simple.
> Noch einmal danke sehr.
corquando
Michael Bauer
The variable is cleared, or overwritten respectively, automatically as soon
as you write the next file name into it. However, atch1="" will also do it.
Best regards
Michael Bauer
Am Fri, 26 Feb 2010 21:39:48 +0000 schrieb corquando:
> > through it,
> > for instance with:
>> for i=1 to count
> > next
>> > > Best regards
> > Michael Bauer
>> Herr Bauer:
> > send:
> Code:
> > For i = 2 To z
> > y = 0
> > With iMsg
> > .To = EML
> > .CC = ""
> > .BCC = ""
> > .Subject = Subj
> > .TextBody = strbody
> > Loop
> > .Send
> > End With
> > 27 Next
> > [\code]
C
corquando
Alrighty, then . . .
I'd tried that, but it still 'stacked up' the attachments; then I
noticed that I had only one CDO session opened, and was looping through
the records within that one session. Evidently the session was
remembering the attachments and sending them as they piled up.
What I finally did (using the 'Atch="" ' command) was to loop through
the records, opening and then closing a CDO session for each email. It
still went just as fast, so evidently that's acceptable.
Thanks and best regards!
corquando
A How to assign the value returned by the regex execute function to a variable? Using Outlook 1
J Automatic color category according to variable domains Outlook VBA and Custom Forms 4
B InputBox for variable folder Outlook VBA and Custom Forms 7
D Outlook Rules - How to use a variable in the subject condition Outlook VBA and Custom Forms 9
M Modifying Macro MoveAgedMail(2) - use categories & "to" as variable Using Outlook 12
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
E Outlook could not create the work file. Check the temp environment variable Using Outlook 8
M VSTO C#: How do I declare an application scope variable? Outlook VBA and Custom Forms 2
L Macro/VBA to Reply All, with the original attachments Outlook VBA and Custom Forms 3
A Attachments.Delete Outlook VBA and Custom Forms 3
shrydvd vba to secure zip attachments Outlook VBA and Custom Forms 3
R fetching blocked attachments Outlook VBA and Custom Forms 0
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
R Outlook is NOT removing attachments. Using Outlook 4
Dan_W Nested email attachments Outlook VBA and Custom Forms 4
S DRAGGING MAIL AND ATTACHMENTS TO CALENDAR Using Outlook 1
G Download pdf attachments only if email subject has one of words Outlook VBA and Custom Forms 8
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
I Forwarding attachments in email received Outlook VBA and Custom Forms 3
M Outlook 2016 msg attachments Using Outlook 0
M Macro for attachments download adjustment Outlook VBA and Custom Forms 3
Diane Poremsky Save Messages and Attachments to a New Folder Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
