Outlook's button 'Attach File' does not work
Tanya
I am creating simple mail using Microsoft.Office.Interop.Outlook. I do not
want to attach file in the code - I need simple mail without any attach. Mail
is successfully created and opened, but after this button 'Attach File' does
not work (it could be clicked, file could be selected but it is not
attached). Here is simple code:
Dim Outlook As New Outlook.Application
Dim OutlookMessage As Outlook.MailItem
OutlookMessage = Outlook.CreateItem(OlItemType.olMailItem)
OutlookMessage.Display()
I am using Outlook 2007.
Could anyone help me with this?
K
Ken Slovak - [MVP - Outlook]
Where is this code running? Is it in an Outlook addin or standalone code or
what?
Do you get any errors when you try to attach something or does it just not
work?
Does the Attach File button in the Insert tab work?
Does Attach File work if you open an item yourself and not with code?
Offhand I can't see any reason why that code wouldn't allow an opened item
to attach things.
"Tanya" <Tanya> wrote in message
news:C2E1A06C-CAC0-45E5-BE1F-2FC663715B6E@microsoft.com...
> Mail
> does
Tanya
This code is running from standalone application. It is VB.Net code, you
could run it and then in opened Outlook window press Attach File button in
the Insert tab. As I said it works a bit funny - attached file is not shown
but will be sent. In case new mail is created from Outlook this button works
fine. Nevertherless, after opening saved .msg file - same strange behaviuor.
(Outlook must be closed before doing this).
K
Please leave some of the preceding thread, it makes it very hard to maintain
context otherwise.
I'm completely confused now. What do MSG files have to do with anything?
You're now saying if the new mail is created from Outlook the button works?
That's what you said didn't work before.
news:9277A80D-EA84-4F07-8716-44799E1C4FE5@microsoft.com...
> in
> shown
> works
> behaviuor.
Tanya
Here is code in VB.Net:
This code is running from standalone application. It creates empty mail.
This mail is opened in Outlook window. This window has tab 'Insert' which has
button 'Attach file'. If you run this code and press this button you will
see that it works strange - file can be selected but won't be shown.
In case new mail is created from Outlook this button works fine.
> context otherwise.
> > in
> > shown
> > works
> > behaviuor.
K
I can't repro this here. Using code like yours produces an email where all
the buttons and menu items work correctly.
news:4671AAAB-CD37-4275-BE44-EC761C902AB1@microsoft.com...
> has
K
Please leave part of the preceding thread in your posts.
So if Outlook wasn't already running you get this? Then start Outlook, use
GetNameSpace("MAPI") to logon and maybe wait a bit to let Outlook finish
starting up. Then do the rest of the code. If that isn't enough you might
need to display Explorer UI (using the GetExplorer method).
news:2D26A5C4-82F6-4FE6-B9F7-05E3EEA65420@microsoft.com...
> Bug is reproduced with closed Outlook only.
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
Wayne Dardis Calling Ribbon Button in Outlook 2016 Outlook VBA and Custom Forms 6
H Preventing the Send button from being clicked on an Outlook Form Outlook VBA and Custom Forms 1
G Moving "Delete" button on Outlook for Mac Using Outlook 1
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
J Outlook 2003 freezing when clicking on TO button Using Outlook 2
M Open new outlook form from within existing outlook form using command button Using Outlook 4
A outlook 2013 people hub :: phone button Using Outlook 1
D Outlook 2007 Scheduling assistant button missing Using Outlook 1
B Greying out the theme button in outlook Using Outlook 0
C Missing "Customise Outlook Today" button Using Outlook 4
P Minimize button causes Outlook to close 2007 Using Outlook 1
C How do I set up an option button in and Outlook form? Outlook VBA and Custom Forms 1
A Custom form - hitting 'next item' button hangs Outlook Outlook VBA and Custom Forms 2
S Outlook Email Help: Select custom voting button options VBA Outlook VBA and Custom Forms 1
D Outlook 2003 saving option button Outlook VBA and Custom Forms 1
G Outlook 2007 Meeting Item Send Button Outlook VBA and Custom Forms 10
N Disable control CTRL button when dragging items/folders - Outlook Outlook VBA and Custom Forms 2
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
T Customize button image for separate Outlook forms region Outlook VBA and Custom Forms 2
W Override the 'To' Button in Outlook Outlook VBA and Custom Forms 3
R About state of encrypt and sign button for outlook? Outlook VBA and Custom Forms 7
R Encrypt and sign button while word is editor for outlook? Outlook VBA and Custom Forms 6
U Not able to delete Add-in button from multiple Outlook Explorer Outlook VBA and Custom Forms 1
C How to assign icon to a button in Outlook Add-in Outlook VBA and Custom Forms 1
V Outlook behaving oddly Using Outlook 2
M HTML email signature in Outlook Using Outlook 1
M Respond to Outlook Email Outlook VBA and Custom Forms 0
U Outlook locking up when replying to Email Using Outlook 7
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
P Syncing Outlook & iPhone Calendars Using Outlook 4
S Unable to extract text from an Outlook email message Using Outlook 2
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
F Outlook 365 is "Possessed" Using Outlook 2
e_a_g_l_e_p_i Can someone explain syncing with Outlook and Gmail Using Outlook 3
