OL Sub through or by Excel Macro Call
C
corquando
Greetings & Supplications, Oracles.
If what I've seen so far is true this may be harder than it should, but
I have to try.
The task is to call an Outlook sub from an Excel macro, or have the sub
BE an Excel macro that then does in Outlook what it's supposed to. The
object is to save 3 attachments from a particular weekly email to a
shared folder then move the email itself to another shared folder.
There will always be 3 (5 is right out) attachments.
This would seem elementary; I am growing dubious.
Anyway, here's the code so far:
Sub SASGET()
On Error GoTo GetAttachments_err
Dim ns As NameSpace
Dim Inbox As MAPIFolder
Dim SubFolder As MAPIFolder
Dim Item As Object
Dim Atmt As Attachment
Dim FileName As String
Dim i As Integer
Dim Carbon As New FileSystemObject
Set ns = GetNamespace("MAPI")
Set Inbox = ns.GetDefaultFolder(olFolderInbox)
Set SubFolder = Inbox.Folders("Specials")
i = 0
If SubFolder.Items.Count = 0 Then
MsgBox "The Big Darn Report has not arrived." + vbCrLf + vbCrLf + _
"Please email the King and let him know.", vbInformation, _
"Nothing Found"
For Each Item In SubFolder.Items
For Each Atmt In Item.Attachments
If Atmt.FileName = "Version1.csv" Then
FileName = "G:\Huge Folder\Medium Folder\Small Folder\" & Atmt.FileName
Atmt.SaveAsFile FileName
i = i + 1
If Atmt.FileName = "Version2.csv" Then
i = i + 1
If Atmt.FileName = "Version3.csv" Then
i = i + 1
Carbon.MoveFile Item.FileName, "G:\Big Folder\Open Folder\Shared Folder\+Format(CDate(Now),""mm.dd.yy"")+"".msg"""
Next Atmt
Next Item
If i 0 Then
MsgBox "Big Darn Report attachments were saved. This is good.", _
vbInformation, "WIN!"
GetAttachments_exit:
Set Atmt = Nothing
Set Item = Nothing
Set ns = Nothing
GetAttachments_err:
MsgBox "An unexpected error has occurred." _
& vbCrLf & "Please note and report the following information." _
& vbCrLf & "Macro Name: GetAttachments" _
& vbCrLf & "Error Number: " & Err.Number _
& vbCrLf & "Error Description: " & Err.Description _
, vbCritical, "Error!"
Resume GetAttachments_exit
The code runs great (except for the Carbon.MoveFile statement - can't
seem to find the right set-up for that.) I just need to either have a
trigger in the Excel code that's running or have it be Excel code that
accomplishes the same task.
And there we have it. As always, many, many thanks!!
corquando
K
Ken Slovak - [MVP - Outlook]
Outlook automation code can certainly run in Excel, just reference the
Outlook object library as a reference in the Excel VBA project and don't
assume an implicit Outlook.Application object. So your NameSpace code line
would use an Outlook.Application object that you instantiated.
Another, unsupported, method is to declare your Outlook VBA Sub as Public
and put it in the ThisOutlookSession class module. You still need an
Outlook.Application object though. Say your Outlook.Application object is
olApp then you'd call the Sub this way:
olApp.SASGET
"corquando" <corquando.5fbc006@outlookbanter.com> wrote in message
news:corquando.5fbc006@outlookbanter.com...
> I have to try.
> Code:
> Sub SASGET()
> Dim ns As NameSpace
> Dim Item As Object
> Dim i As Integer
> i = 0
> "Nothing Found"
> Exit Sub
> End If
> i = i + 1
> End If
> i = i + 1
> End If
> i = i + 1
> End If
> Next Atmt
> Next Item
> If i 0 Then
> End If
> Set Atmt = Nothing
> Set Item = Nothing
> Set ns = Nothing
> Exit Sub
> GetAttachments_err:
> End Sub
> > corquando
F VBA to move email from Non Default folder to Sub folders as per details given in excel file Outlook VBA and Custom Forms 9
T Cannot connect to main BT email account, sub accts okay Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
O Set columns for all (sub)folders Using Outlook 8
F VBA routine to write new sub routine in outlook Outlook VBA and Custom Forms 0
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
D Sub folders of my Inbox collapsing Using Outlook 0
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
W Shared inbox sub folders not visible when moved Using Outlook 3
G Creating Contact Sub Folders Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Missing sub-contact folders (distribution lists) Using Outlook 3
D Monitor any changes to a sub-folder Outlook VBA and Custom Forms 4
G Categories - Sub Catergories Using Outlook 6
D How do I mail-enable a Public Folder Sub-folder in exchnage 2007 using shell ? Exchange Server Administration 0
R Private Sub Application_ItemSend() -Cannot make this code work in Outlook 2013 Using Outlook 0
A How to move responded emaisl automatically to sub folders in Outlook 2007 Using Outlook 0
J Incoming emails going to wrong sub-folder Using Outlook 4
T Unable to download e-mail sub account in OL 2010. No probs with Mailwasher Using Outlook 6
T Make sub folders of inbox appear BOLD when new mail arrives Using Outlook 10
D User cannot move email messages within Outlook Inbox folder and sub-folders. Using Outlook 0
G bcm 2007 sub folders BCM (Business Contact Manager) 1
Y Images coming through as Cid:image in outlook Using Outlook 0
Rupert Dragwater Scrolling through Directories hesitates Using Outlook 1
A Outlook incompleted tasks has strike through Using Outlook 3
H Custom autoforwarding, sending mail through outlook office 365 Using Outlook 1
A Sending Emails Through Outlook From Multiple Email Addresses Using Outlook 1
T Can't send email through connected account (outlook.live.com) - goes to Drafts folder Using Outlook.com accounts in Outlook 3
Tim King Send mail from MSWord through Outlook Using Outlook 3
P Threat to being a spammer while sending automatic Emails through VBA Using Outlook 3
S Ask user to input email template through VBA Outlook VBA and Custom Forms 1
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
Stefanos Update Sharepoint tasks through Outlook Using Outlook 2
L Outlook 2007 Search Through E-Mail Using Outlook 41
R Outlook Cache Mode Terminalserver disable through Registry Using Outlook 1
T Synchronize outlook appointments through web application. Using Outlook 1
L Cannot send emails through @live.co.uk account in outlook 2013 Using Outlook 0
L Cannot send emails through @live.co.uk account in outlook 2013 Using Outlook 2
