Compiler Error: Does not like Outlook.CommandBarControls.CommandBarControlPtr.Add
Shawn
I have a sample program below that I'm trying to convert to the newer mso.tlh (the code has not been updated for years). So, I had to add all of the "Outlook::" and "Office::" since the old tlh did not have the namespace defined in the tlh file.
Down on the bottom of this code that I have extracted, I keep getting the compiler error that it does not how I'm trying to use "Add". I have tried various parameters with no success. What is wrong with it before I burn my hair off my head. :/
Outlook::_Explorer *pExp;
Office::_CommandBars *pCBs;
Office::_CommandBarButton *pBtn;
Office::CommandBar *pOurBar;
Office::CommandBarControls *pApplicationCommandBar;
long buttonpos;
HRESULT hResult;
string toolbar_name;
buttonpos = 1;
toolbar_name = "Application";
if (m_pOutlookApp == NULL) {
return S_FALSE;
try {
hResult = m_pOutlookApp->ActiveExplorer(&pExp);
} catch (_com_error) {
debugoutput("[%s:%d] Exception when trying to get active explorer\n", __FILE__, __LINE__);
if (pExp == NULL) {
debugoutput("[%s:%d] Could not get a active explorer\n", __FILE__, __LINE__);
return S_FALSE;
try {
hResult = pExp->get_CommandBars(&pCBs);
debugoutput("[%s:%d] Exception when trying to get pointer to command bar\n", __FILE__, __LINE__);
if (pCBs == NULL) {
debugoutput("[%s:%d] Cannot load command bar.\n", __FILE__, __LINE__);
return S_FALSE;
try {
pOurBar = pCBs->GetItem(toolbar_name.c_str());
pOurBar->Delete();
m_pApplicationCmdBar = pCBs->Add( toolbar_name.c_str(),
_variant_t((long)Office::msoBarTop),
vtMissing,
_variant_t(VARIANT_TRUE, VT_BOOL));
m_pApplicationCmdBar->Protection = Office::msoBarNoCustomize;
pApplicationCommandBar = m_pApplicationCmdBar->Controls;
// Add a button
Compiler barfs on the following "Add"...
pBtn = pApplicationCommandBar->Add( _variant_t((long) Office::msoControlButton),
vtMissing,
vtMissing,
_variant_t(buttonpos++),
Complier error below is generated for the "Add" above... why?!
error C2679: binary '=' : no operator defined which takes a right-hand operand of type
'class _com_ptr_t
class _com_IIID
struct Office::CommandBarControl,&struct __s_GUID _GUID_000c0308_0000_0000_c000_000000000046
(or there is no acceptable conversion)
Shawn
Nobody has a clue to help me out? Am I'm leaving something out to help me? Do I have a bad tlh/tli files? Where can I get the latest tlh/tli files to make sure that I have the correct version?.
K cannot instantiate abstract class - Compiler error. Outlook VBA and Custom Forms 3
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 5
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 3
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
M Error 0x 800CCC92 Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message New Slipstick.com Articles 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
