Synchronization Error of contacts and calender using Outlook connector
I'm using MS Outlook 2007 for my hotmail account with outlook connector ( Outlook Hotmail Connector Version 14.0.4760.1000)
it was using it with perfect ease but due to some reasons i had to change my Laptop and i deleted my account from my laptop. on the new laptop i installed windows and added my account in MS Outlook same way using outlook connector .. it was working fine. i got my windows corrupted and i reinstalled my windows and added my hotmail account using outlook connector but this time i retrieved all my mail folder but not even a single mail is retrieved. at the bottom with server status there is Error sign which tells
Mail Connected
Calender Error
Contacts Error
and in detailed report i find this report:
Account: Address@hotmail.com
Signed in successfully at 7/11/2010 10:11:18 PM
Mail: Last successfully refreshed at 10:11 PM.
Calendar: Error at 10:11 PM.
Contacts: Error at 10:11 PM.
Errors :
Time: 7/11/2010 10:11:20 PM
Error in Calendar
Synchronization error.
Time: 7/11/2010 10:11:21 PM
Error in Mail
Error with Send/Receive.
There was an error synchronizing your folder hierarchy. Error : 80004005.
Time: 7/11/2010 10:11:23 PM
Error in Contacts
Network operation failed
Error in Mail
There was an error synchronizing a contacts folder. Error : 8004103a.
Send/Receive progress is simply completed without retrieving any mail.
i uninstalled MS office twice removed my account and re add it twice but nothing worked.
i even repaired my MS Office 2007 but it didnt work as well.
its all three days fighting with this issue i'm unable to find solution.
In sync Issues local failure folder is empty but when whenever is send/receive there is a report is Sync Issue like this :
22:13:09 Synchronizer Version 14.0.4760
22:13:09 Synchronizing Mailbox 'Address@hotmail.com'
22:13:09 Synchronizing Hierarchy
22:13:09 26 folder(s) updated in online store
22:13:09
22:13:09
*Request*
22:13:09 00:00:00:0000
22:13:09 GET
22:13:09 http://
22:13:09 sync.calendar.live.com
22:13:09
22:13:09
*Response*
22:13:09
22:13:09
22:13:09 Synchronization error.
22:13:09 Folder Collection Sync Key: 0{e2b50d90-982d-4c48-aed0-85de58b82e95}23
22:13:09 Message Collection Sync Key: 0{906ab573-8ccf-41c0-bd46-931e19f173b9}22
22:13:10 Error with Send/Receive.
22:13:10 There was an error synchronizing your folder hierarchy. Error : 80004005.
22:13:10 Synchronizing server changes in folder 'Calendar'
22:13:10 Synchronizing server changes in folder 'Contacts'
22:13:11 Network operation failed
22:13:11
22:13:11
*Request*
22:13:11 22:13:10:0125
22:13:11 POST
22:13:11 http://
22:13:11 contacts.msn.com
22:13:11 /ABService/ABService.asmx
22:13:11
22:13:11 <ABFindAll xmlns="http://www.msn.com/webservices/AddressBook"> <abId>00000000-0000-0000-0000-000000000000</abId><abView>Full</abView><deltasOnly>false</deltasOnly></ABFindAll>
22:13:11
22:13:12
22:13:12
22:13:12 Error with Send/Receive.
22:13:12 There was an error synchronizing a contacts folder. Error : 8004103a.
22:13:12 Synchronizing server changes in folder 'Drafts'
similarly Synchronizing server changes in folder 'Folder 1 ,2 ,3 ,4' and so on....
I'm just tired PLEASE HELP!!!!
Do you have any mail in the junk folder? Any large messages? (over 3MB)
Empty the junk mail in Outlook, empty the deleted items folder and if you have any large messages, move them to a local pst or Shift+Delete them.
you can also delete the blocked and safe senders lists for the hotmail account in outlook (select a folder in the account then go to the junk email settings).
well i deleted all mails bigger than 3MB and i have nothing in safe sender and block senders
i tried all these things but nothing worked... :(
Have you uninstalled the connector and reinstalled it?
What firewall do you use? Is your antivirus scanning email?
i disabled my Avast antivirus, deleted my account from Outlook, uninstalled outlook connector, then reinstalled and added account again,.......Same problem...:(
It could be a transient error that will clear up on its own... that happens fairly often with hotmail but we have no way of knowing if its your problem. :(
Do you need calendar and contacts? If not, use POP3 for your live mail.
chuckl45
I am having exactly the same problem with Outlook 2007 in WindowsXP Pro x64. Under Windows 7 Ultimate x64 (I dual-boot) it works just fine. I have 3 hotmail accounts and get the same errors with all 3 of them. Again, Windows 7 works just fine, WindowsXP doesn't.
I have done everything I have read to do. Used MicrosoftFixit to COMPLETELY remove Office 2007, ran CCleaner to be sure, and reinstalled Office. After reinstalling, when I open Outlook, my address book is back even though I hadn't imported it yet, the "deleted" accounts are back and the same errors all over. Am I going to have to reinstall WindowsXP to clear this up?
It's not a problem with hotmail, Thunderbird works just fine.
Did you make a new profile in Control panel, Mail? Start with one account, see if it works ok then add another.
Is there a 4 digit error code in with the sync errors?
chuckl45
This is a copy of the error message I get:
Outlook Hotmail Connector Version 14.0.6106.5001
Account: jollymon1953@hotmail.com
Signed in successfully at 4/13/2012 8:16:36 AM
Mail: Last successfully refreshed at 8:18 AM.
Calendar: Error at 8:18 AM.
Contacts: Error at 8:18 AM.
Errors :
Time: 4/13/2012 8:16:37 AM
Error in Calendar
Error in Mail
Time: 4/13/2012 8:16:38 AM
Error in Contacts
Error in Mail
There was an error synchronizing a contacts folder.The network connection is unavailable or interrupted. Please try again later.
Time: 4/13/2012 8:18:22 AM
Error in Calendar
Error in Mail
Time: 4/13/2012 8:18:23 AM
Error in Contacts
Error in Mail
I created a new Outlook profile under Control Panel>Mail......no change.
Again, if I boot into Windows 7 and open Outlook 2007, everything works fine. My new install of Outlook 2007 in Windows XP does not. From what I can see, all relevant settings from one OS to the other are the same.
This - There was an error synchronizing your folder hierarchy. Error : 80004005. - makes me thing its a folder name - but if so, it should fail on the other install too.
Check your safe/blocked senders list in outlook - if there are names on it, export them then delete them from outlook. Also check your junk mail settings - are they the same as in hotmail online?
chuckl45
Would you believe I have no "safe/blocked senders list" other than having checked "trust email from my contacts"? There were NO safe or blocked senders online. My junk folder was empty in Outlook AND online.
Anyway, I gave up out of frustration, installed Windows Server 2008 R2 (instead of WindowsXP Pro) and then installed Office 2010 WITHOUT Outlook Connector. I entered my email account information using pop3.live.com/smtp.live.com, ports 995/587 and security protocol TSL and.......everything works fine.
Thanks for your suggestions.
That works too... and if you only need inbox email, not other folders or calendar and contacts, its a good solution. (As an FYI, pop3 works on XP too. :))
T Synchronization error event Outlook VBA and Custom Forms 4
G Automatically delete messages in the synchronization folder Outlook VBA and Custom Forms 1
R Outlook 2010 Contact Synchronization - Outlook to Outlook.com Using Outlook.com accounts in Outlook 1
Paul Van Cotthem Is calendar synchronization between Office 2013 and Outlook.com capped by spam or bandwidth limits? Using Outlook.com accounts in Outlook 12
A Synchronization of IMAP folders Using Outlook 0
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
J Synchronization of some deletions failed [0-130] Exchange Server Administration 6
M Synchronization of some deletions failed [0-130] Using Outlook 3
S Improving synchronization of Outlook with ... everything else Using Outlook 1
D BCM and remote synchronization BCM (Business Contact Manager) 1
Aussie Outlook 365 Rule runs manually but returns the error code "an unexpected error has occurred" when incoming mail arrives Using Outlook 0
Cathy Rhone Mail merge error message Using Outlook 2
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
