Flag outgoing mail by word in body
Maezeppa
I would like to be able to create a rule that upon hitting 'send' will search the body of the email for the word "attached". If found, the rule will then offer me the chance to confirm one last time that a file attachment is required and present and if not, remedy the situation.
A Flag outgoing email messages in Outlook 2010 Outlook VBA and Custom Forms 0
E Remove flag automatically Using Outlook 4
T Can't reposition "Flag Status" column Using Outlook 0
R Outlook 365 update sets delete from server flag Using Outlook 2
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
G Flag for Follow Up with a customized duetime Using Outlook 1
Diane Poremsky How to Easily Change the Private Flag Using Outlook 0
mikolajek Add on for customized flag operations? Using Outlook 4
B on flag message event - create task Outlook VBA and Custom Forms 22
A Custom Flag Form Outlook VBA and Custom Forms 2
mikecox Missing alarm flag Using Outlook 2
smokiibear follow-up flag fro Tasks in Outlook 2010 Using Outlook 5
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
A Post Form Follow Up Flag Using Outlook 4
S Flag Completion Using Outlook 0
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
A automatically remove flag from original message when a response was received Using Outlook 2
J Macro to periodically sort emails by flag status? Using Outlook 1
2 Flag for Follow up or create new task Using Outlook 1
L Flag settings Using Outlook 1
D Setting the Reminder flag in VBA for e-Mails sent to users Outlook VBA and Custom Forms 5
S Adding follow flag for me by macro (MSO2007) Outlook VBA and Custom Forms 3
D Assign categories to outgoing emails Outlook VBA and Custom Forms 0
oliv- How to distinguish whether mail is incoming or outgoing? Outlook VBA and Custom Forms 2
I categories for outgoing email Outlook VBA and Custom Forms 7
A Categorize Outgoing Mail Outlook VBA and Custom Forms 3
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
F Outgoing mail from Outlook.com sticks in Drafts folder Using Outlook 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
Diane Poremsky Common Outlook Outgoing Server (SMTP) Errors Using Outlook 0
