Post outlook connector installation syndrome - Standby gone
ivan33
A new version of Outlook Connector was automatically dowloaded to my PC.
After the installation I noticed that my Stanby function does NOT work any more.
Neither the Standy button on keyboard works, not is there a icon in the Start menu to go to Standby.
What happened?
IVan 33
ivan33
I resolved the problem. I thought that the new Outlook Connector download casued the problem, but it looks like the Adobe download caused it,
I just did a Restore to previous time, when Standby worked, and now it is OK, even after the new OC was downloaded.
One possibility still exist that I did download a major Microsoft security download at the same time as the Adobe, which may have also caused the problem.
Thanks for the ready reply. I will keep you posted if I find anything new.
Forum Admin
It's possible its because multiple updates were installed at once, but I've also heard the adobe update is causing a number of problems (but not this exact problem). Thanks for letting us know about this problem -
PMR0001 Mydomain Outlook.com and Exchange post EAS Using Outlook 1
H Where to post code in Outlook Outlook VBA and Custom Forms 1
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
O How to delete a forum post? Using Outlook 4
Fozzie Bear Cannot post "Sneaky URL"!! Using Outlook.com accounts in Outlook 2
W "Post" icon on some contacts Using Outlook 1
wallisellener Unable to reply/post/create new thread using Chrome BCM (Business Contact Manager) 5
M Custom form on one page to post contents on second page Outlook VBA and Custom Forms 0
A Post Form Follow Up Flag Using Outlook 4
A POST customized as a form Using Outlook 2
C How do I share/post my calendar to public folders Exchange Server Administration 3
T OWA and post dating Exchange Server Administration 1
B Post form into share calendar Outlook VBA and Custom Forms 1
R Hi, ken, GetState problem again, come in this post please? Outlook VBA and Custom Forms 4
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 3
@ Outlook Using Outlook 2
