HANDLING ERRORS USING FIND
  • Thread starter chuck.grob@invesco.com
  • Start date
C
The code below is what I am using to handle a very unusual situation
(VBA code cannot find an email with 'specific email Subject' as the
Subject).
Is there a better way to do this?
Set olMi = Fldr.Items.Find("[Subject] = 'specific email Subject")
If Not TypeName(olMi) = "Nothing" Then
olMi.Delete
Thanks for your input,
JingleRock
Sue Mosher [MVP]
I'd use something more like this:
If olMi Is Nothing Then
olMi.Delete
Sue Mosher
<chuck.grob@invesco.com> wrote in message
news:801888e3-d5f6-4e55-96d4-2a1f13274593@w9g2000yqa.googlegroups.com...
> Subject).
> olMi.Delete
> End If
> JingleRock
C
Thanks Sue,
I think you meant:
If Not olMi Is Nothing Then
olMi.Delete
If code finds email (it almost always will), then it will be deleted.
JingleRock
Sue Mosher [MVP]
Yes, that pesky Not definitely needs to be there! Good catch.
Sue Mosher
news:2553f5a9-39cc-422a-aa2d-9f951c948caf@e18g2000yqo.googlegroups.com...
> Thanks Sue,
> I think you meant:
> olMi.Delete
> End If
> JingleRock
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
Stig Arvidsson Need a Script for handling moved mail from inbox Using Outlook 3
S Need solution to Outlook mail handling/syncing/mobile situation, please Using Outlook 2
P Handling Multiple eMail Accounts Using Outlook 2
K Handling application.quit event Outlook VBA and Custom Forms 8
S Need: Date handling in Outlook Macros, either information/documentation Outlook VBA and Custom Forms 1
T Outlook 2003 Custom Form Error Handling Outlook VBA and Custom Forms 8
U Adding multiple menu Items. Problems handling the click events Outlook VBA and Custom Forms 1
P errors appear every time I run SCANPST Using Outlook 3
A ScanPST finding errors but no Repair button Using Outlook 2
Y IMAP errors with Outlook 2016 Using Outlook 2
M Charter ISP Claims Outlook Generating STMP Errors of Too Many Recipients Using Outlook 1
Diane Poremsky Common Outlook Outgoing Server (SMTP) Errors Using Outlook 0
M attachments & time-out errors Using Outlook 4
L Issues with Outlook - errors detected in file Using Outlook 1
P 2013 AOL IMAP Sync Errors Using Outlook 5
E Multiple, intermittent Outlook 2010 errors Using Outlook 12
icacream errors have been detected... outlook.pst Using Outlook 10
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
M The set of folders cannot be opened. Errors have been detected in the file. Using Outlook 11
A PDF Attachement Errors with Outlook 2010 Using Outlook 7
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
V What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail Using Outlook.com accounts in Outlook 3
M Outllook 2000 - 2 Errors - The Information Service / The Messaging Interface Using Outlook 7
P IMAP errors with AOL during sync Outlook VBA and Custom Forms 3
B Import to Access errors out Outlook VBA and Custom Forms 20
T field mapping errors during import BCM (Business Contact Manager) 1
D BCM 2007 errors BCM (Business Contact Manager) 5
L Out of memory errors and Auto-linking hangs BCM (Business Contact Manager) 2
R Errors while adding new item to main menu Outlook VBA and Custom Forms 4
