Using /a switch to send multiple files?
U
Um9nZXIgUGl0dGV0
Is there a command line switch to send multiple files. If so, what is the
syntax?
K
Ken Slovak - [MVP - Outlook]
The /a switch can be used to send 1 file as an attachment. No for multiple
files. Search on "command-line switches" in the Outlook Help for
documentation on all the startup switches.
When you post to an Outlook group please always post your Outlook version.
"Roger Pittet" <Roger Pittet> wrote in message
news:20332C08-B326-4D38-A28B-95CEDDDA73A3@microsoft.com...
> syntax?
B Outlook 2010: using /altvba switch Using Outlook 1
