Adding multiple menu Items. Problems handling the click events
U
UkJBaXJhcw
I've added a new menu bar with four buttons to Outlook using the code shown
below (VB code). When it runs, MenuItem1 successfully runs Public sub
MenuItem1_Click(). But when I click any of the other buttons, (MenuItem2,
MenuItem3, or MenuItem4) instead of calling their respective sub(), they
execute all the sub's assigned to the other buttons MenuItem2_Click,
MenuItem3_Click, and MenuItem4_Click, always starting in that order, as if
there was a single sub() instead of three.
What am I doing wrong?
This is the code I use to add the menu bar and its buttos,
VB code:
Private Sub AddMenuBar()
'Get the menu bar in the explorer window.
menuBar = Me.Application.ActiveExplorer().CommandBars.ActiveMenuBar()
'verify that menu does not exist and remove it if it does
newmenu = Me.Application.ActiveExplorer.CommandBars.ActiveMenuBar _
> FindControl(Office.MsoControlType.msoControlPopup, , "Calendarios
de R y D", True, True)
If newmenu IsNot Nothing Then
newmenu.Delete(True)
'Add new menu
menu = menuBar.Controls.Add(Office.MsoControlType.msoControlPopup,
Temporary:=False)
If menu IsNot Nothing Then
'edit the menu properties
menu.Caption = "Calendarios de R y D"
menu.Tag = "Calendarios de R y D"
'add a submenu to the menu and set its properties
MenuItem1 =
menu.Controls.Add(Office.MsoControlType.msoControlButton, , , Before:=1,
Temporary:=True)
MenuItem2 =
menu.Controls.Add(Office.MsoControlType.msoControlButton, , , Before:=2,
Temporary:=True)
MenuItem3 =
menu.Controls.Add(Office.MsoControlType.msoControlButton, , , Before:=3,
Temporary:=True)
MenuItem4 =
menu.Controls.Add(Office.MsoControlType.msoControlButton, , , Before:=4,
Temporary:=True)
With MenuItem1
> Style = Office.MsoButtonStyle.msoButtonIconAndCaption
> Caption = "Calculate Baby's Calendar"
> FaceId = 65
> Tag = "Tag Cloud Submenu"
'.OnAction = "MenuItem1_Click"
With MenuItem2
> Caption = "Calculate Diane's Responsibilities"
> FaceId = 66
> Tag = "Otra nube"
'.OnAction = "MenuItem2_Click"
With MenuItem3
> Caption = "Free Diane's Unmovables"
> FaceId = 65
> Tag = "Otra nube"
'.OnAction = "MenuItem3_Click"
With MenuItem4
> Caption = "Create Diane's Unmovables"
> FaceId = 65
> Tag = "Otra nube"
'.OnAction = "MenuItem4_Click"
'Add an event handler to the menu item
AddHandler MenuItem1.Click, AddressOf MenuItem1_Click
AddHandler MenuItem2.Click, AddressOf menuItem2_Click
AddHandler MenuItem3.Click, AddressOf menuItem3_Click
AddHandler MenuItem4.Click, AddressOf menuItem4_Click
'Display the new menu
menu.Visible = True
Michael Bauer
This example works
http://www.vboffice.net/en/developers/create-new-commandbar-with-one-button
Best regards
Michael Bauer
Am Mon, 6 Apr 2009 09:01:01 -0700 schrieb RBAiras:
shown
if
> VB code:
> menuBar =
_
> .FindControl(Office.MsoControlType.msoControlPopup, , "Calendarios
> End If
> 'Add new menu
> Temporary:=False)
> MenuItem1 =
> Temporary:=True)
> MenuItem2 =
> Temporary:=True)
> MenuItem3 =
> Temporary:=True)
> MenuItem4 =
> Temporary:=True)
> With MenuItem1
> .Style = Office.MsoButtonStyle.msoButtonIconAndCaption
> .Caption = "Calculate Baby's Calendar"
> .FaceId = 65
> .Tag = "Tag Cloud Submenu"
> End With
> With MenuItem2
> .Caption = "Calculate Diane's Responsibilities"
> .FaceId = 66
> .Tag = "Otra nube"
> End With
> With MenuItem3
> .Caption = "Free Diane's Unmovables"
> .FaceId = 65
> .Tag = "Otra nube"
> End With
> With MenuItem4
> .Caption = "Create Diane's Unmovables"
> .FaceId = 65
> .Tag = "Otra nube"
> End With
> menu.Visible = True
> End If
> End Sub
G Removing old emails when adding accounts Using Outlook 3
D Contact Group - Adding Bulk Addresses Using Outlook 2
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
stephenjones Adding a business account to Outlook Using Outlook 1
Chris Grew Adding 2nd Email Address BCM (Business Contact Manager) 3
G Adding an attachment to email I just created (VBA) Outlook VBA and Custom Forms 1
L Adding sender's e-mail to global address book DL Outlook VBA and Custom Forms 1
R Adding vba to script list Outlook VBA and Custom Forms 4
F Adding User Defined Field to another form Using Outlook 0
Edaniels Adding Week Number on Calender Using Outlook 2
