Copying outlook macros between pcs
N
nobug
I have a macro which is activated every time a message is sent.
I'm trying to copy that macro to several others pcs (by vbscript) and
to activate it, but it never does work.
The macro only becomes active once you check the macros menu,
regardless if you activate the macro or just press cancel after viewing
the macros list.
I've tried using the /x tag, but I get an error saying no such macro
exists, althought it does, so I guess the problem is that the macros
list isn't refreshed until that menu is viewed.
Is there any way to force a refresh on the list? or visit that menu via
vbscript?
Thanks a lot for all the help.
nobug
----------------------------------------nobug's Profile: userid=309
?t=96500
Michael Bauer
No, that's the way it works: manually.
Best regards
Michael Bauer
Am Thu, 14 May 2009 08:38:27 +0100 schrieb nobug:
> the macros list.
> vbscript?
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
K Outlook 2010 Not responding after IMAP folder deletion or copying. Using Outlook 2
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
S Calendar items are not being uploaded to outlook.com after copying Using Outlook.com accounts in Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
O New to Outlook 2013, dealing with copying vs. moving sent items Using Outlook 0
D Copying POP3 folders from Inbox to IMAP Inbox in Outlook 2003 Using Outlook 0
N error when copying outlook data "can not copy: the path too deep" Using Outlook 6
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
Thiago Manzano Copying E-mails to a folder on HD Using Outlook 1
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
L Copying Emails using drag and drop Using Outlook 2
S Recover messages that disappeared when copying to folder Using Outlook 1
S Copying multiple messages to folders and keeping date/time detail Using Outlook 1
M Copying setups for mutiple users Using Outlook 2
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
A Copying additional contact fields when chosing "Contact from the same company" Using Outlook 5
A Copying cc email addresses to Excel - does not copy the <joe.bloggs@isp.com> Using Outlook 1
S Search Indexing (Copying Folders) Using Outlook 0
E Copying multiple folders to PST Outlook VBA and Custom Forms 2
B Copying data between atbs in a custom form Outlook VBA and Custom Forms 4
R copying a custom view from a public folder and distributing programatically Outlook VBA and Custom Forms 3
R Copying Data from Exchange to PST file Outlook VBA and Custom Forms 1
V Copying contents from one field to another field Outlook VBA and Custom Forms 6
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
