Simple MAPI send and Outlook COM addin
TWFyayBTbWl0aA
I've got a COM addin that adds a toolbar to Outlook inspectors.
In another process I call the Simple MAPI MAPISendMail function. When the
new e-mail dialog pops up, my addin toolbar does not appear. I figured out
that the same behavior happens if I open up a new send e-mail dialog via the
send to mail shell context menu.
I heard a long time ago that in some cases Outlook opens in a mode where no
addins are loaded. However, even if Outlook is already running (in which
case my addin is already loaded), my addin toolbar does not appear. I ran
through it with a debugger, and none of my code is hit for this particular
inspector.
What if I use Extended MAPI to do this? Since it happens for both Simple
MAPI and the shell send to mail context menu, I'm assuming that it won't work
for Extended MAPI either. Is there something else I can do about this or is
it just a limitation of Outlook?
Mark Smith
K
Ken Slovak - [MVP - Outlook]
When a Simple MAPI message is opened by Outlook any addins will run if
Outlook is running already, and if the addin is correctly written it will
run even if Outlook wasn't previously running. It all depends on how the
addin is written and what it does when OnConnection is fired.
A new Inspector opened from a Simple MAPI message is added to the Inspectors
collection, but it doesn't fire the Inspectors.NewInspector() event. Since
that's how most code will discover an Inspector was opened the code won't
know about the new Inspector, unless you scan the Inspectors collection and
account for any open Inspectors that aren't already being handled.
Using Extended MAPI won't help with this, the limitations would be the same.
"Mark Smith" <MarkSmith> wrote in message
news:9F3BFD98-808A-46B8-89E7-B5EFC5D92D8E@microsoft.com...
> out
> the
> no
> inspector.
> work
> is
> Thanks
> Mark Smith
Mark Smith
Thanks for the reply Ken.
I finally got back to this issue, and I've got a few more questions.
As far as finding the new inspector without the NewInspector event firing,
are you suggesting doing something like a timer based polling? Or is there
some other event to trap? I didn't see anything that looked like it would
work. Maybe I'm looking in the wrong place...
You also say that for the case where Outlook isn't already running the addin
should load. I rechecked my code and the addin does get loaded. However I
tried checking the inspector collection in the OnStartupComplete event, which
is the last one that I get other than the ones for the inspectors or toolbars
themselves. The inspector collection is still empty at this point. So
again, is there some other later event to trap, or am I stuck with a polling
solution here also?
Mark Smith
> > out
> > the
> > no
> > inspector.
> > work
> > is
> > Thanks
> > Mark Smith
K
Polling is the answer to both questions.
news:53BDC2A8-A78C-4B3D-B9A6-681A43B49B6A@microsoft.com...
> there
> addin
> I
> which
> toolbars
> polling
> solution here also?
> Thanks,
> Mark Smith
GregS Simple calendar sharing doesn't work Using Outlook 6
F Simple code to look for a specific line Outlook VBA and Custom Forms 2
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
L Simple Macro Using Outlook 1
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
F I want simple syncing between my 3 PCs and Android devices. Using Outlook 1
H Too simple I would think but.. Using Outlook 1
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
R Simple Sharing of Outlook Profile Using Outlook 1
Rupert Dragwater Is there a genuine simple way to move Eudora address to Outlook 2010 Using Outlook 2
R BCM with MS Office Accounting... Simple question BCM (Business Contact Manager) 0
P Simple Marketing Campaign Question BCM (Business Contact Manager) 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
V simple move to personal folder Outlook VBA and Custom Forms 1
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
J Unwanted US Holiday Contact folder in Outlook.com syncs to MAPI/Phone Address book Using Outlook.com accounts in Outlook 9
P office 2013 communigate mapi Using Outlook 0
S Outlook 2013 MAPI 1.0 Error Using Outlook 2
L Mapi folder.FIND: error Using Outlook 0
J [outlook-users] Icloud + Mapi profile + Using Outlook 1
C MAPI to access a 64 bit Outlook from a 32 bit application; or access via ODBC Using Outlook 0
K Two MAPI Accounts One Contacts data set Using Outlook.com accounts in Outlook 2
E Google MAPI account Outlook VBA and Custom Forms 4
P CDO MAPI Session failing to retrieve user name but Getexchage user Outlook VBA and Custom Forms 2
R Create a new contact use MAPI? Outlook VBA and Custom Forms 2
A Generating valid MAPI URLs for Outlook 2003 Outlook VBA and Custom Forms 2
M Custom mapi is not displayed in the readingpane. Why? Outlook VBA and Custom Forms 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
M How to add a message to a mapi view folder Outlook VBA and Custom Forms 1
T Setting a MAPI property of type PT_SYSTIME Outlook VBA and Custom Forms 4
L Any Replacement for CDO and MAPI ? Outlook VBA and Custom Forms 6
D using extended MAPI Outlook VBA and Custom Forms 1
Q MAPI Read-only Folder Outlook VBA and Custom Forms 3
D MAPI programming issue - outbox doesn't exist? Outlook VBA and Custom Forms 2
