Default settings for "Display as" Change?
Marathon
I have used the macro to reset all my "display as" to Last Name, First name.
However new contacts default to Outlook format.
Any way to change this default behavior to Last Name, First name?
TIA!
tools, options, contact options
"Marathon" <jsssbs@hotmail.com> wrote in message
news:OEzrbXb0JHA.436@TK2MSFTNGP02.phx.gbl...
> name.
> TIA!
Marathon
I know about that setting but the one I am looking to change the default of
is the "Display as" under a person's email address.
The setting you mention will not change that default I do not believe.
"Diane Poremsky [MVP]" <outlookmvp@msn.com> wrote in message
news:%23lnVy1d0JHA.6004@TK2MSFTNGP02.phx.gbl...
> > name.
>> TIA!
Marathon
This particular setting becomes most relevant in a distribution group and
makes it easier to know who is in a large group if display as is sorted just
last, first.
> > name.
>> TIA!
the other setting is in tools, accounts, address book, change.
news:ugoTp4d0JHA.1096@TK2MSFTNGP06.phx.gbl...
> of is the "Display as" under a person's email address.
>> or point
> > your
> >> name.
>>> TIA!
Marathon
Are you sure?
What I have on 2003 is tools, email accounts, address book, view or change
existing..., change. and that does not do it
news:uaxxZLe0JHA.1712@TK2MSFTNGP03.phx.gbl...
>>>> or point
> >> your
> >>> name.
>>>> TIA!
What options do you see there when you look at it?
This is what the dialog looks like on my Outlook 2003 systems:
http://www.xsolive.com/Outlook Screen shots/Forms/DispForm.aspx?ID=93
That changes the sort order in the address book. If you want an order
different from either First Last or your File As order, you need to use the
macro to change it.
Tools, Options, Preferences tab, Contact Options change the File As order
(and type in order).
news:uslDnke0JHA.1092@TK2MSFTNGP06.phx.gbl...
> Are you sure?
>> or point
> > your
>>>>>> or point
> >>> your
> >>>> name.
>>>>> TIA!
Marathon
Yes I have that, but it is the attached "Display as" Field that I want to
only say "Last, First"
news:u1Vv8cj0JHA.4800@TK2MSFTNGP06.phx.gbl...
> the
> macro to change it.
> > Are you sure?
> > change
>>>> or point
> >> your
> >>> default
>>>>>>>> or point
> >>>> your
> >>>>> First
> >>>>> name.
>>>>>> TIA!
You are limited to 2 options for display as - first last or file as. You
need to choose file as format in the address book dialog to use the file as
format then set the file as format (tools, options, contact options) to use
last, first.
If you want some other format for File as, then you need to run the macro to
update the names (or edit it yourself as you create the contact).
news:ubfymPk0JHA.1092@TK2MSFTNGP06.phx.gbl...
> > the
> > macro to change it.
>> or point
> > your
> >> Are you sure?
> >> change
>>>>>> or point
> >>> your
> >>>> default
>>>>>>>>>> or point
> >>>>> your
> >>>>>> First
> >>>>>> name.
>>>>>>> TIA!
M Change default "automatically test account settings when Next is clicked" Using Outlook 1
wallisellener BCM - restore default settings BCM (Business Contact Manager) 36
H Where does Outlook 2007 save the default reminder settings? Outlook VBA and Custom Forms 1
A force outlook to default to MY calendar Using Outlook 3
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
V Accepted meetings do not get the default reminder Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
D Default Send Account that Works? Using Outlook 0
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
J Setting default address book Using Outlook 0
C Change default colors for conditional formatting Using Outlook 2
S Default Font in body of Task Using Outlook 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
Diane Poremsky Shared Mailboxes and the Default 'Send From' Account Using Outlook 0
Diane Poremsky Working with VBA and non-default Outlook Folders Using Outlook 0
Diane Poremsky To Change the Default E-mail Program in Windows Using Outlook 0
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
