Correct way to Identify is Mail is opened in Edit Mode
SklHTkVTSA
Initially I thought in NewInspector event
if EntryID == null then consider it as a new mail and Inspector window
gets opened in Edit mode.
But its not always fact, if i doubleClick on mail item from Outbox or Sent
folder it does have EntryID and Inspector window gets opened in Edit mode.
So just checking for EntryID == null will not work.
What is the correct way to identify. Is mail is opened in EDIT mode.?
- Regards
Dmitry Streblechenko
Use the MailIterm.Sent property.
Dmitry Streblechenko (MVP)
"JIGNESH" <JIGNESH> wrote in message
news:34044D5E-1038-4362-ABA5-8285E29CE542@microsoft.com...
> Hi
> mode.
> - Regards
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
L Email with correct To address but displaying name of a related person Using Outlook 0
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
Thorsten show the correct calendar on start Outlook VBA and Custom Forms 5
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
R VBScript Sendmail not selecting correct 'from' address Outlook VBA and Custom Forms 3
M Large emails not sent from correct account Using Outlook 0
J Importing to the correct calendar from Excel 2010 to Outlook 2010 Outlook VBA and Custom Forms 2
A phone numbers fields in BCM are not correct BCM (Business Contact Manager) 3
E Getting Outlook full name correct with AddressLayout Using Outlook 1
D Journal problem recording correct phone number Using Outlook 7
B Outlook 2010 asking for password constantly, won't accept correct one Using Outlook 5
M help correct code Using Outlook 0
J Correct settings for send/receive groups w/Exchange Using Outlook 3
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
D How to correct Outlook Connector Live ID Using Outlook.com accounts in Outlook 1
D appointments on To Do Bar don't reflect the correct Calendar Using Outlook 3
M Auto-correct Contact fields' formatting? Using Outlook 7
S Send receive with ATT returns this error: 0x800CCC92 . My password is correct. Using Outlook 2
K Why is OL not keeping the correct sender account? Outlook VBA and Custom Forms 1
E Some question if I understand user properties correct Outlook VBA and Custom Forms 3
Q Need advice for correct event Outlook VBA and Custom Forms 1
I Identify Number of email messages opened Outlook VBA and Custom Forms 7
S VBA to identify a specific email and copy the attachment from it to the network Outlook VBA and Custom Forms 4
makinmyway How can I easily identify and delete from my contacts defunct email addresses? Using Outlook 2
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
S Identify weekend from daily RecurrencePattern Outlook VBA and Custom Forms 2
S Identify Read Recepits Outlook VBA and Custom Forms 7
H Better way of writing Macro? Identify multiple types of attachmen Outlook VBA and Custom Forms 5
D How to identify a mail item from a public folder in MS Outlook Outlook VBA and Custom Forms 5
Aussie Outlook 365 Rule runs manually but returns the error code "an unexpected error has occurred" when incoming mail arrives Using Outlook 0
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
Cathy Rhone Mail merge error message Using Outlook 2
