How to setup signature with Outlook 2007 with external picture
fbosquet
We used signatures for send "advertising" with our email wich change every month ...
With outlook 2003 I add the picture with his external link (http://xxxx.xxx/xxx.gif) and when the external picture change each month when the users close and then open outlook the new picture is displayed in signature ...
With outlook 2007 that don't work because even if I add the picture with his external link when I save the signature outlook take in and to a local file ... it create a local folder with image001.gif and the html of the signature go to this local image and not to the external link ...
So when the external image change the users in outlook 2007 stay with the old (what is a big trouble because the images are for monthly promotion ... and when you send a email to customer saying that a product had a rebate of 2500 $ but it's wrong ... it's difficult to explain that's a trouble of outlook signature ...)
Can you give me a solution ? We used GPO so if needed we can change some settings by GPO ... or by login script ... we used Kixtart script ...
Thanks !
You need to set a reg key in outlook to use external pics.
HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Outlook\Options\Mail
Value name: Send Pictures With Document
Value: 0 to link, 1 to send pic.
(Same value works with 2010 too, just need to use the right path in the registry)
fbosquet
I try it but when I create my signature it always create local folder with image is it correct ?
the signature is XXXX and in the signature folder it create a "XXXX_files" folder with a file image001.gif in it wich is the http://www.xxx.xxx/advertise.gif localy saved and renamed to image001.gif ...
Same thing that before add the registry key ...
Thanks !
Blitherski
Outlook 2007
So Diane...I have done this on several machines in an office, but ran into something interesting on both outlook 2010 and 2007 when editing the registry- that directory location does not exist. I can get to the final outlook folder on some, and even the options folder on some, but then no Mail folder. Any thoughts on where it would be? One issue might be that these are machines which have been updated from earlier versions of outlook, but I checked the other folders (8.0, etc) and its not there either.
It's odd that you don't have the full path, although Outlook only creates the keys if you change options that are stored in that path (most people do make at least one or two changes) - create it if it doesn't exist.
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
T Interim Outlook 365 Setup Using Outlook 2
Marc2019 Cannot setup Outlook Account on Mac Os 10.6.8 Using Outlook 3
Z Account setup on Android Using Outlook 3
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Q Mail account setup query Using Outlook 0
Laurent Duchastel New email setup dialog doesn't allow alias Using Outlook 2
mrje1 Outlook 2016 Manual Email Account Setup, what is the Office 365 option etc., and Crashes Using Outlook 0
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
C GoDaddy office 365 setup wizard erased old Outlook emails? Using Outlook 14
B New Outlook 2013 setup Using Outlook 8
D Setup expire date for incoming mail Outlook VBA and Custom Forms 2
Ayzad Proper setup to work with iCloud sync? Using Outlook 5
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
C iCloud can't setup Outlook 2010 32bit Win 7 64 Using Outlook 11
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
J Want to 'modernise'(?) my email setup using Outlook. Any advice? Using Outlook 0
jChambler setup of iCloud with Outlook 2007 fails Using Outlook 4
D Setup of Outlook2013 insists on using OST for an IMAP account. Using Outlook 5
S iCloud Setup Using Outlook 4
P Changing from POP to IMAP; will this setup work? Using Outlook 1
V iCloud and Outlook 2007 iCloud - Initial setup with live data on all machines Using Outlook 2
V Outlook 2007/2010 - First time iCloud setup and config for heavy Outlook user Using Outlook 1
V Yahoo E-Mail Setup Using Outlook 2
J calendar print setup in outlook 2010 Using Outlook 1
G Outlook 2013, Windows 8 and Windows Phone 7.5 WP7.5 Setup Using Outlook 11
J How-to setup Outlook 2010, Windows 7-32bit, iPhone (so they work and play tog. Using Outlook 3
B Two server DAG setup, second server EMC not opening Exchange Server Administration 3
A can u setup o/l to autodelete 2g of email when it reaches 3g on a 4g mailbox? Using Outlook 7
C Outlook Shared Folder setup Exchange Server Administration 3
S How to setup a company calendar Using Outlook 3
C crash during account setup - can't delete corrupted account/data file Using Outlook 13
T More than one outlook account to setup & move Using Outlook 1
F BCM Setup Problem BCM (Business Contact Manager) 2
P Outlook 2010 and Microsoft Setup Bootstraper... Using Outlook 1
A Why not using DAG virtual IP/fqdn for CAS array in two nodes setup? Exchange Server Administration 2
M How do I get the version number of the Setup project? Outlook VBA and Custom Forms 1
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
P Setup failed to install Business Contact Manager for Outlook 2007 BCM (Business Contact Manager) 2
