Outlook 2003: Help with setting up a macro to reply to selected emails
Steph
Hello, I was wondering if someone could help me with writing the code, and with the actual series of mouse clicks I need to take to set up the macro (as I am relatively new to this), to do the following:
I want click on an email (without opening it), then just run a macro that sits on my toolbar, that replies to the selected email, with the text "I have no further info."
Most grateful for any assistance :)
Cathy Rhone
Outlook 2013 32 bit
Exchange Server 2010
I'm not a coder but you'll want the macro to reply (easy) then write in the body, also fairly easy especially if you don't need to include the quoted text. look for code samples at outlokocode.com.
It might actually be easier to kick the macro off on the reply event - it will be fewer keystrokes, although it will make it harder to reply and not run the macro. :)
O Duplicate folders in Outlook 2003 Using Outlook 3
O Moving OUtlook 2003 from bad XP to Win 7 Pro 64 -- URGENT! Using Outlook 8
R Menus in a new\old email not there in Outlook 2003 Using Outlook 2
R OUTLOOK 2003 on WinXP, Prob: CONTACTS or ADDRESS BOOK not connected or missing Using Outlook 6
