Follow up: Make a combo box dependant on another
Q
QW15IEJyb29rcw
Hi Sue,
Regarding the previous question, could I add more code to have a third combo
box relate to the second?
Amy
Sue Mosher [MVP]
Again, that's going to depend on whether the 2nd combo box is bound or not.
If it is, you add another Case block to the CustomPropertyChange event
handler to handle the change in that property. If not, you use the control's
Click event. See the previously suggested article.
Sue Mosher
"Amy Brooks" <AmyBrooks> wrote in message
news:044BE2A3-61C3-47AA-A1C1-29B3BEB13388@microsoft.com...
> Hi Sue,
> combo
> Thanks,
> Amy
Q
QW15IEJyb29rcw
Bound is when it saves the selections when closed?
If so, I think they are bound.
If they are, how would I go about adding another case block? There are more
values now, is that still the way to go?
> > Sue Mosher
> > Hi Sue,
> > combo
> > Thanks,
> > Amy
Sue Mosher [MVP]
Yes, that's one of the characteristics of bound controls.
The second Case block to handle a second property's value changes would go
right after the first, as in the example at
http://www.outlookcode.com/article.aspx?ID=38.
Sue Mosher
news:368AA6CF-2374-4D66-BBE8-622DAC1E50E4@microsoft.com...
> more
> > not.
> > control's
>> > > Sue Mosher
> > > Hi Sue,
> > > combo
> >> > Thanks,
> > > Amy
Q
QW15IEJyb29rcw
So maybe something like:
---------------------------------------------------------------Sub Item_CustomPropertyChange(ByVal Name)
Select Case Name
Case "Division"
Call SetSubDivision
Case "SubDivision"
Call SetThirdBox
___________
Sub SetSubDivision
Set objInsp = Item.GetInspector
Set objPage = objInsp.ModifiedFormPages("General")
Set SubDivision = objPage.Controls("cboSubDivision")
Select Case Item.UserProperties("Division")
Case "Ambulance"
SubDivision.List = Split("Air,NHS,Private,Vehicle Builder,Voluntary",",")
Case "Export"
SubDivision.List = Split("Distributor,End User,Ferno Group",",")
Case "Hospital"
SubDivision.List = Split("Distributor,MOD,NHS,Private",",")
Case "Industry"
SubDivision.List = Split("N/A",",")
Case "Mortuary"
SubDivision.List = Split("Distributor,Funeral Director",",")
___________
Sub SetThirdBox
Set ThirdBox = objPage.Controls("cboThirdBox")
Select Case Item.UserProperties("SubDivision")
Case "NHS"
ThirdBox.List = Split("Option A, Option B",",")
Case "Private"
ThirdBox.List = Split("Option C, Option D",",")
(etc.....)
---------------------------------------------------------------"Sue Mosher [MVP]" wrote:
> > Sue Mosher
> > more
> >> not.
> >> control's
> >> > >> Sue Mosher
> >> > Hi Sue,
> >> > combo
> >> >> > Thanks,
> >> > Amy
Sue Mosher [MVP]
Exactly. That's how you build on what you've learned!
Sue Mosher
news:C60F2640-4A07-4E46-9E18-7C11B3D8FF2F@microsoft.com...
> ---------------------------------------------------------------------------------------------> Sub Item_CustomPropertyChange(ByVal Name)
> Select Case Name
> Case "Division"
> Call SetSubDivision
> Case "SubDivision"
> Call SetThirdBox
> End Select
> End Sub
> ___________
> Sub SetSubDivision
> Case "Ambulance"
> Case "Export"
> Case "Hospital"
> Case "Industry"
> Case "Mortuary"
> End Select
> End Sub
> ___________
> Sub SetThirdBox
> Case "NHS"
> Case "Private"
> (etc.....)
> End Select
> End Sub
> ---------------------------------------------------------------> "Sue Mosher [MVP]" wrote:
> > go
> > > more
> > >> not.
> > >> control's
> > >> > Hi Sue,
> > >> > third
> > >> > combo
Q
QW15IEJyb29rcw
Great stuff, thanks for all your help Sue!
> > Sue Mosher
> > ---------------------------------------------------------------------------------------------> > Sub Item_CustomPropertyChange(ByVal Name)
> > Select Case Name
> > Case "Division"
> > Call SetSubDivision
> > Case "SubDivision"
> > Call SetThirdBox
> > End Select
> > End Sub
> > ___________
> > Sub SetSubDivision
> > Case "Ambulance"
> > Case "Export"
> > Case "Hospital"
> > Case "Industry"
> > Case "Mortuary"
> > End Select
> > End Sub
> > ___________
> > Sub SetThirdBox
> > Case "NHS"
> > Case "Private"
> > (etc.....)
> > End Select
> > End Sub
> > ---------------------------------------------------------------------------------------------> > "Sue Mosher [MVP]" wrote:
> >> go
> >> > more
> >> >> not.
> >> >> control's
> >> >> > Hi Sue,
> >> >> > third
> >> >> > combo
C Outlook 365 Can you change the follow up colour? Using Outlook 1
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
O Outlook 2016 follow-up flags--how can I add dates? Using Outlook 1
G Flag for Follow Up with a customized duetime Using Outlook 1
G Follow up and Using Outlook 1
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
oliv- HOW TO GET PROPERTIES FOLLOW UP Outlook VBA and Custom Forms 7
D No Follow up when making new form Outlook VBA and Custom Forms 2
rc4524 Create auto follow-up reminder email for already sent messages Outlook VBA and Custom Forms 1
smokiibear follow-up flag fro Tasks in Outlook 2010 Using Outlook 5
A Post Form Follow Up Flag Using Outlook 4
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
R Flagged for Follow Up Search folder MIA after PST export/import Using Outlook 1
M adding marked emails under follow-up Using Outlook 2
2 Flag for Follow up or create new task Using Outlook 1
N Mark or follow up emails in shared mailbox Using Outlook 2
H "For Follow Up" items missing. Using Outlook 5
B Multiple follow ups Using Outlook 1
S Adding follow flag for me by macro (MSO2007) Outlook VBA and Custom Forms 3
P Custom Outlook form_Validations in combo box Outlook VBA and Custom Forms 0
F Outlook 2010 - outlook userform and combo boxes Using Outlook 9
S Outlook form - Combo box for deciding who to send form to Using Outlook 1
M details with the combo box Exchange Server Administration 3
M Need help with combo boxes in messages! Using Outlook 10
L Combo Box Using Outlook 157
Q Make a combo box dependant on another Outlook VBA and Custom Forms 5
Q Load a recipient based on a value in a combo box Outlook VBA and Custom Forms 7
