Please help. My live.edu mail will not sync.
docrhymer
I just built a new desktop and installed Win7 Ultimate, office 2010 32bit.
Then I tried to sync my school email which is @live.ndm.edu, it will not send and receive.
I added the account using Outlook connector and yes it is the lasted version.
The error code it it gives me is as follows
Task 'xxxx@live.ndm.edu/ reported error (0x8004102A) : 'Error with send/receive.
There was an Error synchronizing your folder hierachy. Error : 80041004'
Task 'xxxx@live.ndm.edu/ reported error (0x8DE00005): 'There is an error
synchronizing your mail account. Please verify your account is configured correctly by
first accessing your mail on the web. Error 3203. Client. Mailrelayprovisioned
accounts re not supported.'
So here are things I have done already to resolve this issue.
- reinstall the connector / readd the account
- 4 different versions of MS outlook (2010, 2007 in 32/64 bits)
I tried adding my plain @hotmail.com account and it is sending/receiving emails with no problem.
Also this @live.ndm.edu email syncs flawlessly on 2 other PCs running office 2010. (Both running diff Win7)
Can anyone tell me what the problem?
Is the account configured the same way on the other computers? Is the outlook connector the same version on all computers?
Also, verify the computer date, time, and time zone are correct (within 5 minutes). If there is a wide difference in the time, it can cause errors.
A Help with VBA please! Outlook VBA and Custom Forms 15
C Please Help outlook 2013 Using Outlook 1
J Please help to clarify an IMAP issue Using Outlook 7
M Address book doesn't update contacts? Please any help would be great! Exchange Server Administration 4
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
A help please -Boolean - can I use .AND NOT etc in a rule Exchange Server Administration 0
C Can't import distribution list - help, please Using Outlook 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
V [duplicates duplicates duplicates] please help Using Outlook 26
I can't view email body please help! Using Outlook 6
S Please help! -- Linked Account field at Business Contacts tab is always empty BCM (Business Contact Manager) 1
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
D Help please my Outlook is frozen Using Outlook 3
H Outlook 2010: Cannot start!, please help me! Using Outlook 3
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
M Updates to exchange server broke code - please help Using Outlook 2
K shared inbox help please Using Outlook 0
P Please Help me Create a Macro ! Using Outlook 2
J Help please Using Outlook 30
D A little bit of help with headers please? Exchange Server Administration 1
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 5
L PLEASE HELP: reconnect existing PST file to imap account Using Outlook 1
B Please help! Outlook, Exchange Server, and Customization BCM (Business Contact Manager) 2
B Please help! Outlook, Exchange Server, and Customization Exchange Server Administration 0
C outlook hotmail connector update killed my outlook - please help!! Using Outlook.com accounts in Outlook 3
M Help with shared BCM file please BCM (Business Contact Manager) 5
R i want notifier in outlook express , please help how can i get ? Outlook VBA and Custom Forms 1
R SQL Server Setup failed - Please help?! BCM (Business Contact Manager) 2
L Please help an idiot with BCM & Networking... BCM (Business Contact Manager) 5
C Outlook 2007 Wacky Issue - Please Help Outlook Wishlist 1
V Import multiple vCard files!!!!!!! PLEASE HELP Using Outlook 2
V Outlook macro help please Outlook VBA and Custom Forms 23
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
Diane Poremsky Testing please ignore Using Outlook 1
