Anyone found a way to customize search?
chockomonkey
I love how BCM has instant search and filter fields everywhere, however it sometimes doesn't include the field we need to search on. Has anyone here found a way to tell BCM, "hey... search these fields as well!"
that'd be sweell,
thanks!
chockomonkey
AFAIK, the filters are not customizable beyond what the fields they offer.
Sorry if I wasn't clear--the filters actually do offer the field "Office Location", but we're trying to get the instant-search boxes to recognize this field as well. We often need to look up "NY Group" or w/e we have in that field to see all accounts belonging together.
Have you seen a place to do this?
larry
Interesting, that field is available in Advanced Find but not in Instant search (at least not as office or offlicelocation)
chockomonkey
Googling around, I found a post on the BCM blog. It's regarding BCM 2007, but it is directly related to what I'm trying to do.
A link to the post: http://blogs.msdn.com/b/bcm/archive...s-for-search-in-business-contact-manager.aspx
This excerpt is about custom field searching, it references some search operators which no longer seem to work.
Q: Is it possible to search user -defined fields?
A: In the Instant Search box, type the user -defined field name followed by a colon :)) and the value you are searching for. For example, if you have a user-defined filed called “Contract terms” and you are searching for”4”. You would type:
Contract terms: 4 in the Instant Search box.
Does anyone remember using these in 2007 BCM? They don't seem to work in my 2010 version. I can't see any reason they'd have for removing the ability to use search operators. maybe they've just changed?
ginstt
eHow to get sexy legs like this? (PIC)?
eI was shocked those 3 states went blue in 2008, I did think the Democrats would win but not those 3 states, do you think those states are going to remain blue states now?rnrnIf so why? If not why?
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 2
J Can Anyone Help?? Outlook VBA and Custom Forms 1
V Anyone Using CodeTwo Sync for iCloud ? Using Outlook 28
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
M Anyone with this Microsoft Outlook issue can help? Using Outlook 1
R Anyone have a sample macro for Outlook 2007 (setting the zoom)? Outlook VBA and Custom Forms 1
rubaboo The vew cannot be found Outlook VBA and Custom Forms 0
noshairwan Registry cannot be found, Outlook Security Using Outlook 2
shrydvd Highlight found RegEx pattern Outlook VBA and Custom Forms 3
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A VBAProject.OTM Not Found Outlook VBA and Custom Forms 2
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
G Calendar folder cannot be found (tasks folder cannot be found) Using Outlook 2
T Desktop alerts show but no emails found Using Outlook 1
R Inbox search, current folder, it's in there-but not found. Using Outlook 2
K After Carbonite restore pst files are found in a weird location Using Outlook 2
R Exchange - Locating a user that has log files but is not found using powershell Exchange Server Administration 1
G Script in rule to send to multiple emails found in message bo Outlook VBA and Custom Forms 11
J An attempt operation failed. An object could not be found at line5. Outlook VBA and Custom Forms 2
O "Cannot create message because a data file...could not be found" Using Outlook 1
R Clip art search alway no result found in Outlook 2010 Using Outlook 1
C Odd error message not found in Google search Using Outlook 1
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
E Outlook PST files disappear, only found temp file HELP: Using Outlook 1
R Lost Outlook 2007 message found in OWA Using Outlook 4
A 5.7.1 Recipient not authorized, your IP has been found on a block list Using Outlook 1
O Lost attachment found but hidden in msg! Help!! Using Outlook 1
D Found and Lost Outlook Add-ins Using Outlook 0
C User defined field not found in any views prints. Cannot locate to delete. Using Outlook 2
K Outlook insert clip art, no results found...address book contacts only show up Using Outlook 5
B Task List in To-Do Bar 'The operation failed. An object could not be found' Using Outlook 3
M The macro name.ThisOutlookSession.DisplayMyForm cannot be found. Outlook VBA and Custom Forms 2
M Cannot Send - "Operation failed. An object cannot be found" BCM (Business Contact Manager) 4
A path of documents can't be found BCM (Business Contact Manager) 1
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
A Customize meeting form. Private notices Outlook VBA and Custom Forms 3
J Customize Attachement Security Warning Using Outlook 1
