What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail
Vocalpoint
After struggling with this thing for weeks now - and completely rebuilding my workstation from scratch using a fresh install of Office 2010 and a fresh install of Outlook Connector AND after practically deleting everything from my Hotmail acct (no email, no calendar events, no nothing - all I have left is my 40 contacts) Connector still kicks up stuff like Synchronization Errors, Windows Live Error 0x8004102A and ALL it's variants.
I am at my wits end here. Is this thing just that useless that it cannot even correctly read a practically empty Hotmail acct without failing?
Any ideas on what I can do next? Because I am about one step away from dumping Outlook completely and going right to Windows Live Mail - which handles everything perfectly.
My primary reason for even bothering with Windows Live is the calendar functions that sync nicely to on my Samsung Android rather than having to mess around with trying to manually sync the phone to my local Outlook every day.
Hoping someone can steer me in the right direction.
Cheers,
VP
Re: What is wrong with Outlook Connector - it still errors out on an EMPTY Hot
Is there a 4 digit error code? That generally helps more with connector errors.
Do any of the contacts have unerscores or other non-alphanumeric characters in the address or name?
Do you have names in the blocked or safe list?
BTW, if Live mail meets your needs, use it.
Vocalpoint
Yes - I have a boatload of error codes. Some of them include are:
0x80004005 - Network Operation Failed
0x80004102A - There was an error syncing your folder hierarchy. The network connection is unavailable or interrupted. Please try again later
0x80004103A - Synchronization Error.
0x8004A165 - Synchronization Error. Unable to synchronize item.
No - I have no contacts with special characters. And to ensure ALL contacts were out of the picture - as part of my testing - I exported ALL the contacts out and ensure every contact was deleted on the Hotmail side. So there were no contacts at all to sync - and it still threw errors.
No names or anything in any blocked or safe senders list. (from the Outlook side - and none on the Hotmail side)
Still hoping for some ideas on what to check :)
VP
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
B Sharing Outlook calendars gone wrong Using Outlook 0
Z Outlook for G Suite emails showing wrong dates Using Outlook 4
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
P Outlook 2013 rules -- not working reliably -- moving messages to wrong boxes Using Outlook 0
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
G Outlook 2013 display the wrong font Using Outlook 7
T Change from exchange server to pop when I set up outlook wrong Exchange Server Administration 1
S Outlook 2003 - showing meeting on wrong day and time Using Outlook 1
D Outlook sends e-mails using the wrong account Using Outlook 0
R How to configure outlook to avoid sending emails from the wrong account Using Outlook 24
L wrong icon displayed for outlook custom form Outlook VBA and Custom Forms 8
M Something went wrong and your search couldn't be completed Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
N Copies of emails from rules have wrong from: account Using Outlook 0
A Replies being sent from wrong account Using Outlook 8
W Sending To Wrong Account Using Outlook 15
C How to avoid sending mail to the wrong contact person Using Outlook 1
Diane Poremsky Warn before sending messages to the wrong email address Using Outlook 1
M Messages in Outbox reminder is wrong Using Outlook 4
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
B you are not responding to the latest message - wrong email Using Outlook 1
E Recurred tasks are created with a wrong due date Using Outlook 0
Diane Poremsky The calendar shows the wrong day at the beginning or end of the month Using Outlook 0
J Calendar search failing & wrong indexlocation showing..OL2010 Using Outlook 3
e_a_g_l_e_p_i Is something wrong with my themes Using Outlook 3
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
Commodore Wrapping and wrong encoding Using Outlook 2
G Onding e-mail with wrong signature Using Outlook 0
O BCM Dbase Issues (both not seeing dbase & not allowing restore for wrong owner BCM (Business Contact Manager) 2
L Schedule Assistant shows wrong working hours Using Outlook 1
S Wrong email account displayed in folders Using Outlook 3
J Incoming emails going to wrong sub-folder Using Outlook 4
G appointment times are wrong Using Outlook 3
V Wrong Address List being used (or Resolved by ALT + K) Using Outlook 1
V meeting displayed at wrong time Using Outlook 4
K Quick Print shows wrong date on Occurrences Using Outlook 1
K Business account window is wrong BCM (Business Contact Manager) 1
S Restrict method question on email. What am I doing wrong? Outlook VBA and Custom Forms 2
G wrong body .msg coding Outlook VBA and Custom Forms 6
D Application.ActiveInspector().CurrentItem Returns Wrong(Old) Value Outlook VBA and Custom Forms 3
D Exporting reports to Excel gives wrong numbers BCM (Business Contact Manager) 1
D Wrong Form view in "Developer" Tab for "Accounts" BCM (Business Contact Manager) 4
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
