Is there a genuine simple way to move Eudora address to Outlook 2010
Rupert Dragwater
Outlook 2013 64 bit
Apart from spending bucks on a program i.e. Transend, is there a way for one to move ones' address book from Eudora Pro to Outlook 2010? I've used Aid4Mail and it moved my folders over no problem. But I understand that program will not do the trick when it comes to the address book. I know Transend will for a mere 50 dollars plus.
If there is a slick way to do what I'm asking, please advise. If not, kindly disregard this notice.
(Perchance anyone does not see this post / question, please do advise me immediately)
Cathy Rhone
Outlook 2013 32 bit
Exchange Server 2010
Can you export the address book in a format outlook can import? Most programs can export in CSV format - Outlook can import CSV. I haven't used Eudora in 15 yars so I have no idea if it supports CSV. :(
Rupert Dragwater
Outlook 2013 64 bit
There is nothing in Eudora to Export - only to import. Any other ideas - others are permitted to come in on this too you know!!! :)
D Need Genuine Office or Outlook 2007 Using Outlook 3
GregS Simple calendar sharing doesn't work Using Outlook 6
F Simple code to look for a specific line Outlook VBA and Custom Forms 2
K Ask about a simple script about save a incoming mail as file on local PC Outlook VBA and Custom Forms 3
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
L Simple Macro Using Outlook 1
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
F I want simple syncing between my 3 PCs and Android devices. Using Outlook 1
H Too simple I would think but.. Using Outlook 1
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
R Simple Sharing of Outlook Profile Using Outlook 1
R BCM with MS Office Accounting... Simple question BCM (Business Contact Manager) 0
P Simple Marketing Campaign Question BCM (Business Contact Manager) 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
V simple move to personal folder Outlook VBA and Custom Forms 1
T Simple MAPI send and Outlook COM addin Outlook VBA and Custom Forms 3
Commodore Unable to move message Using Outlook 3
J Dopey move - deleted profile Using Outlook 1
M Move to Folder Using Outlook 1
C Can't move folder, the folder is full Using Outlook 0
