"Replied" messages not in "sent" box, but are appearing in my "inbox" from me
os15
If I get an email from "Jane Doe" and hit "reply" and then "send", the message appears in my "outbox" for a few seconds while it's being sent and then I get a message in my "inbox" with myself listed in the "from" field. The email I sent does not appear in the "Sent" folder.
Also, on a somewhat unrelated, but equally frustrating note, I don't have a "deleted" folder. All emails that I now delete appear to be permanently deleted and I don't see a setting where I can create the folder or point "deleted" emails to it
Any suggestions or help would be greatly appreciated
larry
Re: "Replied" messages not in "sent" box, but are appearing in my "inbox" from
Is this a gmail account? Gmail is weird in their implementation of IMAP. They don't have separate folders - what gmail calls folder are more like tags - and everything goes into one mailbox. Outlook doesn't undersatand the tags and dumps everything in the inbox. You can create a rlue to move them to a folder in the imap account, if you want.
Deleted items should be in the mailbox, until you purge - but the view hides items marked for deletion so you won't seem them. Look on the view menu for a view that will show all messages.
Diane Poremsky Forward Messages that were not Replied To Using Outlook 0
B Replied to messages are being deleted Using Outlook 1
P Replied-to email messages don't sync properly Using Outlook.com accounts in Outlook 3
C Icons (arrows) not showing on emails forwarded or replied to Using Outlook 5
I Check if sent email has been replied Outlook VBA and Custom Forms 1
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
I Email Replied for first time Date/Time Outlook VBA and Custom Forms 2
OnCall "You replied to..." not showing up Using Outlook 1
C Need rule to alert when an email has not been replied to within 24 hours Using Outlook 1
2 Email not replied to reminder - aka boomerang? Using Outlook 3
W "You Replied on" Gets Stripped from Emails after they are Moved to Folder Using Outlook 1
S Outlook macro to move replied / forwarded emails to a seperate folder Using Outlook 1
A In Outlook 2007, need to see the replied/responded date in Inbox view Using Outlook 3
J Deliver new messages to New or Existing Data File? Using Outlook 2
M Messages Intermittently Dont Arrive In Sent Items After Sending Successfully Using Outlook 4
R Why doesn't outlook use "Normal" style for new messages? Using Outlook 4
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
W Receiving messages in offline mode Outlook VBA and Custom Forms 1
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
T SMTP messages stuck in Outbox Using Outlook 0
Mark White VBA to deal with Recalled messages Outlook VBA and Custom Forms 7
