appointment times are wrong
As of sunday, our meeting times are wrong. We're using Outlook 2010 and Windows 7 and are using -5 Eastern time zone and deselect the option to update for DST. Any idea what is wrong?
Forum Admin
Yeah, I know what is wrong - it's your time zone. If you live in a region that does not observe daylight saving time, you need to use a time zone that does not support DST. Windows 7 and Outlook 2010 handle time zones differently than older versions and using a zone but unticking the dst box won't cut it. Sorry.
P Appointment times are off by one minute Using Outlook 1
A Problem syncing any changes to appointment times on PDAs ... Using Outlook 11
J Can't print appointment times on Monthly View Calendar? Using Outlook 4
J Can't print appointment times on Monthly View Calendar? Using Outlook 0
O Calendar - appointment templates and categories Using Outlook 1
W Appointment userproperties disappear Outlook VBA and Custom Forms 4
F Appointment Show All Fields Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
W Appointment occurrences change the location property Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
A Day view - print appointment details Using Outlook 1
R Recover Deleted Appointment in Calendar Using Outlook 0
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
S Appointment colour categories disappear Using Outlook 4
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Create Task or Appointment and Insert Selected Text Using Outlook 0
Pierce007 Maps/location in making an appointment Using Outlook 2
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Create Appointment From Email Automatically Using Outlook 0
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
Diane Poremsky Create an Appointment Diary Using Outlook 0
Diane Poremsky Send an Email When You Add an Appointment to Your Calendar Using Outlook 0
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
F Outlook 2010 Search Appointment Notes Using Outlook 0
D Calendar appointment, type 2 Using Outlook 2
