Company calendar sharing problems
jc_palmer
Hi all,
Outlook 2010 with Exchange 2010 used within our company. Each users calendar to be shared with receptions calendar.
When reception organises appointments for the partners the appointment goes into both the partners calendar and receptions calendar. With 10 partners, receptions calendar will be flooded with duplicate appointments when it would be easier just to view the partners calendar instead. How do we stop the apppointment duplicating into receptions calendar?
Also is there anyway of bypassing the need for the partner to accept the appointment? I want reception to put in appointments for the various partners without having to have partners accept the appointments and flooding inboxes with requests.
Your help would be much appreciated
James
Forum Admin
The receptionist is creating meetings with the partners when she needs to be adding the apt directly on their calendar. Have the partners made the receptionist a delegate? Then she can open their calendars in her outlook and create the appt on the calendar directly. She only needs access to calendar and maybe tasks. Or, you can just give her Editor permission to the calendars instead - this will eliminate problems with her receiving meeting invites. (Right click on the calendar, choose properties, permissions.
Derek Howell Company wide calendar Exchange Server Administration 1
A Create a Company Calendar Using Outlook 1
S How to setup a company calendar Using Outlook 3
O Address list - company and non-company ? Using Outlook 0
T One Contact list, two sections of company (none) Using Outlook 2
Scorpion New Contacts keep coming up as company Using Outlook 1
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
J Subject Field is displaying Name and company Outlook VBA and Custom Forms 1
Karsten V invites from outside company arrives as regular mails Using Outlook 2
Diane Poremsky Update Contacts with a New Company Name and Email Address Using Outlook 0
J Create an appointment from Contact list with the Company name in the Subject line Using Outlook 1
S rule, automatic replies, restricting them to within the company Using Outlook 1
B Full name of contact is now the company name Using Outlook 0
S How to set Company as default "File As" in Contacts for Outlook 2010 ? Using Outlook 1
A Copying additional contact fields when chosing "Contact from the same company" Using Outlook 5
P Addin / macro / rule to highlight email addresses outside company in To: field Using Outlook 3
T search folders to segregate internal e-mails ( from company domain ) vs exter Using Outlook 1
J Entering Contacts at Same Company Using Outlook 1
M Outlook License from Hosting company Using Outlook 1
V No results when I SEARCH contacts under COMPANY NAME . . . . Using Outlook 3
K Autoarchive when contradicting company policy Using Outlook 3
P Company name in Business Projects BCM (Business Contact Manager) 2
T Outlook 2003 - Contacts view by Company Outlook VBA and Custom Forms 1
R Using 'Company Name' in a BCM report!! BCM (Business Contact Manager) 1
F company field won't show in report BCM (Business Contact Manager) 5
T Is any body knows how to add #company name# to report? BCM (Business Contact Manager) 1
S Re: Account / Company / Department (2007) BCM (Business Contact Manager) 1
A new contact from same company BCM (Business Contact Manager) 2
M "File As" option lost company name- Mass change? Outlook VBA and Custom Forms 5
U Button for Company Outlook VBA and Custom Forms 1
A delete company BCM (Business Contact Manager) 1
KeithJB iCloud calendar sync only works one way! Using Outlook 3
O Unable to make changes to an existing Calendar entry Using Outlook 8
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Using Outlook 0
A Meeting organizer calendar intermittently drops meeting after delegate sends invite Exchange Server Administration 0
T Outlook 2010 Cannot edit Calendar entries in OL 2010. Using Outlook 1
M On behalf of not showing on calendar for boss Using Outlook 1
C Outlook 2016 Unable to delete Gmail IMAP calendar Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
O Carriage Return - Line Feeds - exporting Calendar events Using Outlook 0
K How to share multiple calendar items Using Outlook 1
P Calendar Day View only shows 1 all day event Using Outlook 0
Hobbes Outlook 365 Calendar spreads into second calendar Using Outlook 3
