Outlook Signature GPO issues
etowntec
Outlook 2007
In our network we are needing the requirement for users to create their own signatures and then apply them as default to new messages and reply/forwards.
I have looked all over the net for an answer to the problem we are having with this but can't seem to find the correct answer.
In a GPO I set the default signatures to be MySignature once this was done the users lost the abilty to create signatures at all. If I remove that GPO the users can then create signatures and set them to default but once they close and open outlook the signatures they created are still there but the selections they have set for default are back to (none).
Does anyone know of what may be causing the default signature to not stick between outlook sessions?
We are running Outlook 2007 on Windows 7 Professional.
Chad Abbs
etowntec
Outlook 2007
When a signature is set using GPO, it overrides the user defined sigs.
Is there a way that I can have the users create personal signatures and have them stick as default when they close and open outlook again?
I am guessing that we might have a policy or reg setting that is blocking this habit. Also, some of the users affected have regular user accounts (not power users) and some are local admins for their boxes.
M HTML email signature in Outlook Using Outlook 3
B Importing business card into Outlook for SIgnature Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
J Outlook 2013 crashes saving VBA & clicking tools | digital signature Outlook VBA and Custom Forms 1
blashmet Outlook Signature Distorted in Other Email Clients Using Outlook 9
SirFishAlot SIGNATURE EMBED ISSUE OUTLOOK 2013 BCM (Business Contact Manager) 10
X Outlook 2007+ Changing signature also changes subject? Using Outlook 9
S Outlook 2k/2k3 Reply or Forward: Signature image replaced by original sender Using Outlook 3
A Vanishing signature image in Outlook 2010 Using Outlook 1
F How to setup signature with Outlook 2007 with external picture Using Outlook 4
I Creating an Outlook 2007 macro that attaches a signature to new me Outlook VBA and Custom Forms 1
M Outlook 2003 - New message font size different to signature Using Outlook 3
B Outlook 2007 Signature Outlook VBA and Custom Forms 1
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
F Moving Outlook to new PC Using Outlook 0
Ken Pascoe Outlook Categories Quick List Using Outlook 0
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 1
R Rogue Outlook Rule ? Using Outlook 2
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 8
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 7
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 5
S Mac Outlook 365 Questions Using Outlook 1
M Outlook calendar is missing Using Outlook 2
T Have you written an articles about Outlook? Using Outlook 3
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
R Outlook 365 update sets delete from server flag Using Outlook 1
X Outlook automation pull from PDF Using Outlook 5
