issues with OL 2010
turbot
Am having some issues with Outlook 2010. 32 bit.
Program was locking up when receiving emails. I went off line & tried to delete a couple newer large ( 4-10 MB ) emails .
No luck deleting so when back online. Now program does not lock up first thing. Does get stuck on receiving , but can still use the program somewhat.
Emails can be viewed & replied to , but not moved or deleted. Doing this will cause a premanent "processing" icon.
Still thinking those couple large files caused this & would like to find a way to delete them.
Forum Admin
Large mails should not cause a problem with POP3... Hotmail Connector, yes.
It could be the SRS file, although this isn't quite the typical symptoms. Find and delete the SRS file then restart outlook. In Windows 7/8, you can type or paste %appdata%\Microsoft\outlook in the address bar of windows explorer to jump to it.
turbot
Thanks for the info.
Deleted SRS file for that profile, no change.
Other profiles work file.
Icon on lower bar says " Outlook is syncing folders "
Outlook is getting stuck receiving 1 of 6 messages 7kb of 1.5 mb.
Have gone into ISP mail portal & deleted all incoming mail. Looks to be trying to receive messages from couple days ago ?
turbot
Thank you for taking the time to help.
There are 4 profiles on this computer. other 3 work fine.
Am trying MFCMAPI. When try to "open dfault message store " this mesage appears.
Error: Store does not support the IExchangeManageStore interface
Code: MAPI_E_INTERFACE_NOT_SUPPORTED == 0x80004002
Function lpMDB->QueryInterface( IID_IExchangeManageStore, (void **) &lpIManageStore)
File MAPIStoreFunctions.cpp
Line 868
Following your instructions page , we continue on to #3
Tip: you can right click on the account in the list and choose Open Store instead.
3. Right click on Root Container and choose Open Contents Table
Click "Open Contents table" & next page to appear is labeled " Display name not found " & page shows 0 items.
Does this mean no hidden messages are stuck ?
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Christopher M ( CMAR606 ) Outlook 2010 IMAP issues Using Outlook 2
W Outlook 2010 Task bar issues. Using Outlook 8
P Outlook 2010 2 Accounts - Issues Using Outlook 0
C Outlook 2010 Custom Form Issues Using Outlook 2
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
B Exchange 2010 / Outlook 2010 - Group Folder issues Exchange Server Administration 6
R BCM 2010 Beta - Sharing issues BCM (Business Contact Manager) 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
E Imported Contact Issues Using Outlook 11
D Event ID issues Exchange Server Administration 2
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
O Outlook 2016 contact issues Using Outlook 2
J Office 365 and Outlook connection issues Using Outlook.com accounts in Outlook 3
Kris Petorv Calendar issues Using Outlook 0
Diane Poremsky Internet Mail Issues with Outlook Using Outlook 0
Diane Poremsky Mail Issues with Outlook Using Outlook 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
J Issues in Canceling iCloud Configuration and Reverting to Local PST Configuration Using Outlook 0
Commodore Two Sync Issues folders Using Outlook 4
P Outlook 2013 and IMAP: Two popular issues Using Outlook 3
S send/receive issues outlook 2013 Using Outlook 4
P Folder issues using Gmail with Office 2013 Using Outlook 3
L Group Inbox Send As/Send on Behalf Issues Using Outlook 3
VCC Icloud/Outlook Syncing Issues Using Outlook 1
mwh1962 Sync issues with Windows 8.1 phone Using Outlook 2
M Outlook 2007 IMAP Account Rules Issues Using Outlook 3
J Outlook 2013 and outlook.com issues when using mail alias Using Outlook.com accounts in Outlook 2
mikecox Multiple unexplainable issues Using Outlook 1
G Issues with accessing Outlook Contact Picture with VBA Outlook VBA and Custom Forms 4
J Office 365 small business/Outlook 2013 issues Using Outlook.com accounts in Outlook 1
L Issues with Outlook - errors detected in file Using Outlook 1
D Sync issues Using Outlook 1
R Outlook 2013 IMAP Sync Issues Using Outlook 1
V Outlook 2013 - iCloud add-in creates issues Using Outlook 4
A Contact Group issues Outlook 2013 Using Outlook 1
V In Box Issues Using Outlook 1
