Mark moved copies as "Read"
Zviedrs
Dear Diane Poremsky,
I have a year old problem and hopefully with your help I can solve it.
I have created rules to move a copy of every message I sent to a specific Inbox folder. It works fine, but every moved copy shows up as "unread". It takes time to go through all folders and click every copy to be read, therefore - is there a solution to do it automatically? So far on internet I have not found any..
P.S. I still want to have also an original sent message in my Sent Items folder.
Thank you in advance,
Best regards,
Zviedrs
Zviedrs
Yes, I have seen that and have tried to put that in use for several times, but it have not worked so far. Maybe I do something wrong with that function. (Also it keeps pointing at "Private WithEvents Items As Outlook.Items" as compiling error).
Besides, if I read correctly it is for "Use a folder in another pst or Mailbox" but I have the same pst file, maybe here is the broblem?
Thank you in advance!
Zviedrs
I now see more explanations you gaved, but I am still confused.
1.) You write that I don't need all the code from the page.. you mean that I don't need that function and just this?
Sub Whatever()
Dim Ns As Outlook.NameSpace
'use the default folder
Set Items = Ns.GetDefaultFolder(olFolderCalendar).Items
'do whatever
2.)"When the folder is a subfolder under the default Calendar folder, use this instead:
Set Items = Session.GetDefaultFolder(olFolderCalendar).Folders("SharedCal").Items" - I copy messages not only to one Inbox subfolder, but to almost fifty.. Does this still apply in this form? Or I need to copy it fifty times and each time show new subfolder in "SharedCal"?
Is "olFolderCalendar" for any folder or it determins "Calendar" and should be changed to "olFolderInbox" in my case?
3.) If
Set Items = GetFolderPath("New PST\Sent Items").Items
End Sub"
Should be at "ThisOutlookSession" - then what I exactly copy elsewhere and exactly where - into Module1?
Many thanks again!
Did you put the code at the Top of ThisOutlookSession? Not doing so is one cause of the compile error.
That code, as written, is for moving mail to another pst folder - but it can be used for local folders by changing the folder path or use the code sample at VBOffice.net, linked in the More Information section.
Sub Whatever()
'do whatever
No, that is just sample code. The function you need is under Use a folder in another pst or Mailbox
Using it with 50 is more difficult - you need 50 macros (one for each folder) or a different method.
Are you replying to messages already in those folders? If so, Outlook has a setting to move sent items into the folder with the original when its not in the inbox. It would be better to use that when possible.
3.) If
End Sub"
You don't necessarily need a module 1 for this code, the GetFolderPath function can go in ThisOutlookSession or in Module 1.
Sub Whatever()
'do whatever
3.) If
End Sub"
Zviedrs
Thank you, but I am still going crazy over here..
What I have now is:
Set Items = Session.GetDefaultFolder(olFolderInbox).Folders("TEXT").Items
Item.UnRead = False
Item.Save
Function GetFolderPath(ByVal FolderPath As String) As Outlook.Folder
Dim oFolder As Outlook.Folder
Dim FoldersArray As Variant
Dim i As Integer
On Error GoTo GetFolderPath_Error
If Left(FolderPath, 2) = "\\" Then
FolderPath = Right(FolderPath, Len(FolderPath) - 2)
'Convert folderpath to array
FoldersArray = Split(FolderPath, "\")
Set oFolder = Application.Session.Folders.Item(FoldersArray(0))
If Not oFolder Is Nothing Then
For i = 1 To UBound(FoldersArray, 1)
Dim SubFolders As Outlook.Folders
Set SubFolders = oFolder.Folders
Set oFolder = SubFolders.Item(FoldersArray(i))
If oFolder Is Nothing Then
Set GetFolderPath = Nothing
'Return the oFolder
Set GetFolderPath = oFolder
Exit Function
GetFolderPath_Error:
Exit Function
End Function
> .at the ThisOutlookSession.
1.) Is this correct for Inbox Subfolder "TEXT"?
2.) How can I get this work?.. Cause, if it is only at the ThisOutlookSession, I have no relation to any project and so I can't run this, can I?
3.) Also - if I have another 50 of these to make - do I paste all of them in ThisOutlookSession one after another?
Thank you in advance!!
Forum Admin
I'm checking with the guys who write outlook utility for a living - see if there is a better way.
If not, you would need to combine these two and duplicate it.
Set Items = Session.GetDefaultFolder(olFolderInbox).Folders("T EXT").Items
Item.UnRead = False
Item.Save
Forum Admin
Oh, and you have one other option - disable the option to save sent messages and save (move) them only using rules - use stop processing on every rule and create a 51st rule to save everything else in the sent folder. It's not my favorite and shouldn't be used if the folders are in imap accounts, but it should solve your problem.
Additionally, since you use Outlook 2010 and can view message threads even when filed in different folders, I would consider whether its necessary to move the messages.
Zviedrs
Thank you once again!
I hope to hear the result if any from your other specialists.
Thanks in advance!
Bad news - you'll need 50 macros or 1 macro with the 50 folders listed.
One thought occurred to me - what criteria do you use to move messages? Do you move all sent messages? Maybe instead of using a rule to copy, you could use a macro - but this will work best if the criteria is always the same and the folders are named for the criteria. For example, you copy a message sent to a@b.com to a folder named a@b.com.
Zviedrs
Thank you Diane!
I choose to copy 50 macros then.
But how do I get this macro work?
I have:
Sub Mark_as_read()
At "module 1" to have this macro a name and possibility to run
and:
Item.UnRead = False
Item.Save
at "ThisOutlookSession". And still, messages that I have sent and moved with a rule to Inbox subfolder "TEXT" show up as "unread"...
Thank you in advance once again!..
Zviedrs
P.S. I would preffer one macro with 50 folders listed, but how can I do that?..
I'll have to test some macros and see which way works best. I think one macro with 50 Case statements will work the best since you aren't using a run a script rule (not supported by after sending rules). You won't use the App startup rule, only the item add.
Now that i think about it, using a macro may not work as expected - it's going to mark all mail placed in that folder as read. This is fine if you don't use rules to move mail there, but won't work if you use rules to move new mail to the folder as it arrives, as they will be marked read.
Do you copy all messages you send or just some? Using an itemadd macro that copies mail placed in the sent folder might work better. It will require a bunch of if statements though.
Something like this is what you need to do -
Set Items = Session.GetDefaultFolder(olFolderSentItems).Items
If Left(Item.Subject, 4) = "Test" Then
   Set MoveTo = Session.GetDefaultFolder(olFolderInbox).Parent.Folders("Test")
If Left(Item.Subject, 6) = "[more]" Then
else
If Item.RecipientAddress = "a@b.com" Then
end if
   Item.UnRead = False
   Item.Copy MoveTo
Deleted member 370
Hi, Zviedrs. Advance warning - this is probably a useless response, but just in case it's not, I thought I'd share. I read your query because I have a similar issue - I send a copy of mail from particular individuals to personal folders - faster than filing. I was annoyed to discover that I couldn't find a similar add-on for Outlook that I have for Mail for Mac (it's called Act-On Mail) that allows me to mark the copy read before it files it, or not create the copy until after the mail is read. Eventually I settled on a low tech solution that I'm mentioning because I noticed that you said that it's time consuming to mark each one read: I just open the folders periodically, select all and choose "mark as read." My thought is that I deal with them as read or not in my main inbox - these are just copies that I keep for history. You could do the same for yours if you don't store unread mail in those boxes. I know it's a bit of a pain. You could probably write a macro to mark your entire folder read periodically, but I'm too lazy. There's always some issue with a macro. Of course it won't work for you if you're truly using separate inboxes, in which case...carry on. Ignore me. :)
-Melody
Tribe of Admins
O Office 365 Outlook - mark to download Using Outlook 0
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
S Mark as Unread unless Categorized by Color Using Outlook 0
Diane Poremsky Mark Sent Items as Read After Copying with a Rule Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
F Automatically close email after selecting mark unread Using Outlook 1
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
B Outlook 2010: how to mark messages without opening? Eg for deletion Using Outlook 2
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
N Mark or follow up emails in shared mailbox Using Outlook 2
H mark as read per folder options Using Outlook 1
C Outlook 2010 search for question mark in calendar Using Outlook 7
M Can't mark appointments as private for other user Using Outlook 1
A Mark all as read for public folders Using Outlook 14
I Pound Symbol in emails show as � (black diamond with white question mark inside) - Office 2010. Using Outlook 11
N Changing the 'Mark item as read when selection changes' at runtime Outlook VBA and Custom Forms 1
B Move Sent Email to archival pst folder and mark as read - HOW TO Outlook VBA and Custom Forms 2
B Mark copy of sent email as read - VBA? Outlook VBA and Custom Forms 3
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
J Mark as read Outlook VBA and Custom Forms 2
M Mark as read Outlook VBA and Custom Forms 5
R Macro to mark item unread Outlook VBA and Custom Forms 2
T Setting a delegate to not mark items as read Using Outlook 9
C "The linked image cannot be displayed. The file may have been moved, renamed, or deleted. Verify that the link points to the correct file location" Using Outlook 1
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
C Your mailbox has been temporarily moved ... Using Outlook 2
CWM030 Connected accounts mail moved to trash? Exchange Server Administration 16
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
DAVID A moved the Outlook CST file - All subfolders lost Using Outlook 2
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
Aussie I Change the Subject Line ... but after it is moved the subject has reverted Using Outlook 1
W Shared inbox sub folders not visible when moved Using Outlook 3
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
D iTunes moved Outlook.com Calendar to Delted Items Using Outlook.com accounts in Outlook 3
S Can't move the items. The item could not be moved. It was either already moved or deleted, or access Using Outlook 3
Stig Arvidsson Need a Script for handling moved mail from inbox Using Outlook 3
Commodore Unified inbox shows moved messages for a while Using Outlook 4
W "You Replied on" Gets Stripped from Emails after they are Moved to Folder Using Outlook 1
