Hover display of DL shows original owner, not current
Courtney
I can't find any information on my issue related to Corporate Distribution Lists on the Exchange 2010 server. In OL2010, when you create a new message and enter the DL and do a check name, you can hover over the DL to see the owner info. If the owner has changed, you see it correctly if you open it from the address book, but if you hover over it, it shows the original owner (even if they've been gone from the company for years. We created new OL profiles and it still shows the original owner. I can't see it in Powershell using get-DistributionGroup | fl. I only see the current owner (ManagedBy). Any ideas?
Thank you!!
Courtney
Courtney
Yes Diane, the ExchangeOAB has been updated once a day everyday. I've verified by looking at the files directly \\servername\exchangeoab. As far as Outlook is concerned, I've verified the local OAB files in (C:\Users\username\AppData\Local\Microsoft\Outlook\Offline Address Books\7aa0f1c3-c773-45f3-8742-98075917ce09) are also updated with the current date. Sometimes the original owner still works for the company, sometimes they don't, but when you hover over the DL, it should still show the current owner (ManagedBy).
Any ideas of where to look? Thank you!
O After filtering, how to display all events on that day? Using Outlook 4
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 3
O Tasks - how to display "snoozed" tasks and snooze-times? Using Outlook 7
P Task display now leaves little room for notes Using Outlook 10
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
C Why won't Title display in message list? Using Outlook 1
M Daily Task List Minimized Cannot Display Using Outlook 2
C Outlook Mobile app email order randomized and display names stripped Using Outlook 6
N Contact display as Using Outlook 2
J Reminders Display then Disappear Using Outlook 13
O How to display senders email address (column) Using Outlook 1
O How to display number of items per .pst file Using Outlook 7
O Display more months in 'Tasks' Using Outlook 3
O How to display folder icons? Using Outlook 2
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
copperberry How to display incomplete tasks due on or before 7 days from now Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
P How to make outlook display alert appear on top of other windows whenever a new email is received? Outlook VBA and Custom Forms 1
T Outlook 2016 Calendar multiday event display Using Outlook 4
Diane Poremsky Display the Created Date field of any Outlook item Using Outlook 0
Diane Poremsky Replace Display Names with Email Addresses Using Outlook 0
Diane Poremsky Search for All Messages from Contact and Display in New Window Using Outlook 0
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
Diane Poremsky Display the Recipient Email Address in the Sent Items Folder Using Outlook 0
Diane Poremsky Excel Files Won't Display in Reading Pane Using Outlook 1
D Display of Open Folders Using Outlook 0
Fozzie Bear Change the Display Name recipients see for Exchange account Exchange Server Administration 0
Diane Poremsky Pictures don't display in Outlook messages Using Outlook 4
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
M Display as name in outlook contacts changes Using Outlook 5
R Coming from Thunderbird: "Always prefer display name over message header" Using Outlook 1
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
J Changing margins in received email display Using Outlook 3
