Add categories to Shared Mailbox using VBA
Jeevie
Outlook 2007
Hi All
I need help. I am trying to add / retrieve categories from a shared mailbox attached to my profile using VBA. However when I try adding categories using VBA, it gets added to my personal mailbox. Appreciate any help/guidance to resolve this.
Thanks in advance.
Jeevie
Outlook 2007
I have the owner permission and am able to add the categories manually. I need to figure out a way to do it using VBA.
Regards
Z bulk add categories / with fixed colours / select multiple categories on a not Using Outlook 1
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
