"open" command in right click context menu
PeterUK
In Outlook2003, the right click context menu had the "open" command at the top of the list; i.e. when you have a summary list of emails, you could right click on one of them and select "open" as an option. Now in 2010, the open command has gone and we have "copy, quick print, reply, reply all, forward....etc. down to delete, at the bottom of the list. Is there any way we can have the "open" command back at the top of the list? many thanks and best regards (happy new year too)
PeterUK
There are several items out there which talk about adding customised entries to the bottom of the list, but there is a degree of complexity in what they suggest. thanks for your response.
PeterUK
In some respects double click is the same as open, if you want to open an individual email. However my client wants to view an email in the preview pane and what he is doing is opening other emails separately so he can compare contents etc. If you double click them to open, they replace the one in the preview pane; if on 2003 you right click and open them, the new email opens separately. You are right in that customisation is not apparent for this menu; lets see if there is another approach. If I crack it, I'll report back, but would value anyone's opinion in the mean time.
Forum Admin
Yeah, in a situation like that, it won't work.
The only way to customize the context menu (or ribbon, beyond what is offered) is using a com addin - the ribbon in Outlook in 2007 and up can only be worked with using a COM addin. That puts it out of the realm of most people and why I say it can't be done - for the average user, it's not possible.
M Open new outlook form from within existing outlook form using command button Using Outlook 4
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
K Embedded photos no longer open with Photos or Photo Viewer Using Outlook 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
D after delete mail, open the next one Outlook VBA and Custom Forms 0
M outlook won't open! Using Outlook 1
M other user's mailbox won't open, forms disappeared Using Outlook 42
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
S Reminder Dialog Open Button Using Outlook 2
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
A open Outlook with multiple windows. Using Outlook 0
K open calendar from address book Outlook VBA and Custom Forms 1
T Double clik behavior on agenda open a new meeting request Using Outlook 1
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item Using Outlook 0
Diane Poremsky Rules & Alerts Dialog Won't Open Using Outlook 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open Using Outlook 0
O Cannot open or save calendar items Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 Using Outlook 1
C scanpst.exe will not open Using Outlook 0
B ...administrator has limited the number of items you can open simultaneously Outlook VBA and Custom Forms 7
