Exchange Management Shell closes on command failure
SMAndy
Hi everyone,
My first post, and a question....
My exchange Management Shell (using Office 365, and a hybrid exchange 2010 server) seems to close on its own whenever a command fails to run. (when it kicks out an exception)
This is really annoying because it only gives me about a second to read the error message, unless i can hit Pause/Break fast enough... As you can imagine, I would quite like to find out if its failing because i typed the command wrong or because the action i'm doing is already done (account already exists etc)
Any ideas on how I can fix this? If i look in the properties of the start menu entry for the shell, it has "-noexit" in it, which I assume is something to do with this...
SMAndy
It sounds like you are opening and running it via command line.
Do you have error handlers built into the script?
Error Handling | Windows PowerShell: A More In-Depth Look | InformIT
Windows PowerShell 2.0: TFM (The F****** Manual)
No handlers that I know of...
I'm opening the management shell from the start menu shortcut, (microsoft exchange server 2010 > Exchange Management Console)
Since its powershell, would it use my default powershell profile? i'm loading the ActiveDirectory module and setting the executionpolicy to remotesigned with the profile, so that i can run scripts for creating new PC accounts directly into AD... but that's all the configuration i've got on it.
SMAndy
Failure. It still closes when it throws up an exception.
Example: add-mailboxpermission <rest of="" commands="" required=""
All typed correctly, no mistakes.
exception: this account already has access <error codes="" that="" powershell="" throws="" out=""
*returns to command entry, like its taunting me to try again*
*3 seconds later, powershell closes, regardless what i'm doing*
</error></rest>
D Microsoft Exchange account - Remote management Using Outlook.com accounts in Outlook 1
D Outlook Add-on for Exchange Spam Management? Exchange Server Administration 2
L Exchange Management Console - Initializtion failed on Logon Failure: unknown username or bad passwor Exchange Server Administration 4
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
J Importing N2K from a different Exchange Server Using Outlook 1
I Exchange 2019 - MICROSOFT-CORP-MSN-AS-BLOCK Exchange Server Administration 0
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
I outlook 2016 manual exchange config Using Outlook 0
Fozzie Bear Office 365 Home Premium with Exchange Online email accounts Using Outlook 3
S What is /O=FIRST ORGANIZATION/OU=EXCHANGE ADMINISTRATIVE GROUP(***************)/CN=RECIPIENTS/CN=... Using Outlook 5
Commodore Microsoft Exchange Add-in Using Outlook 2
