outlook error Receiving reported error (0x80040900) please help
alis119
Outlook 2007
hello
i have windows-7 32bits and install ms office 2007
not have exchange server its a pop account
windows server 2003 with isa server 2000 is running in the my network in the windows xp running outlook successful not working with windows 7 error is below
(Task 'alias@mapak.com - Receiving' reported error (0x80040900) : 'The server name you
entered cannot be found on the network (it might be down temporarily). Verify that you are
online and that the server name is correct.')
i have install windows too many time also change the CPU location and checked disable windows update and firewall but problem still same help me find out the solution
Alis119
Triple check the spelling of the server name you entering into the account - the error says outlook can't find it. Is the mail server running on your network or the Internet?
If its a server on your network, it's probably DNS issues. If its on the internet, have you checked ISA logs for errors?
alis119
Outlook 2007
i have windows server 2003 with isa server 2000 dont have any mail server
which kind of isa log can i check could you tell me any log name do u have in your mind yet..?
Just the general traffic logs - I don't have isa 2000 to check (I have the last version of isa and the interface is totally different).
alis119
Outlook 2007
i have check traffic logs and isa policy could not find solution yet. i can send you isa setup if you want to check give ur id or download form the website
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message Using Outlook 0
U .pst file error at opening outlook Using Outlook 1
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
Diane Poremsky Outlook Error Ox800CCC13 in Windows 10 Using Outlook 2
N Outlook 2013 installation error Using Outlook 1
HenWin Outlook 2007 and Comcast certificate error Using Outlook 1
P Encryption Type Error - Verizon and Outlook 2010 Using Outlook 0
M Outlook Email Connection Error Using Outlook 3
T Outlook 2010 sync error Using Outlook 0
H 2010 Outlook 0x800CCC92 Error Using Outlook 2
RBLampert Outlook downloads error out if one particular account is the first to download Using Outlook 0
E Microsoft Office Outlook 2007 Send Error Using Outlook 11
C Error installing BCM: requires outlook BCM (Business Contact Manager) 25
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
E Outlook 2013 default file error Using Outlook 1
H Outlook Error message Using Outlook 10
B Outlook to Word Template error Using Outlook 4
J Just installed Outlook 2010 on computer and user is getting a 0x80004005 error Using Outlook.com accounts in Outlook 1
J Outlook 2007 Error sharing Calendar: Error while preparing to send sharing message Using Outlook.com accounts in Outlook 2
J Customizing PST error message in Outlook Using Outlook 8
R Outlook 2013 cannot send email error 0x700700c1 Using Outlook 1
P Error Message “Your Outlook Data File cannot be configured” Using Outlook 5
S Error after enabling 2-step authentication in Outlook.com/Outlook 2013 Using Outlook.com accounts in Outlook 1
Jon Bakrley Outlook 2013 and Exchange 2007, Out of the office error message Using Outlook 8
J New Outlook 2007 form - try to send and get error Operation Failed Outlook VBA and Custom Forms 11
