Using Outlook 2010 on POP3 to Outlook.com auto deletion on Web
gnbalbion
Hello, I am using Outlook 2010 configured with a POP3 account onto Outlook.com. MS Outlook works fine, it retrieves all messages and deletes them from the Web Inbox. I have unchecked the option to leave a copy on the server so it deletes the original copy on the web server. In MS Outlook following deletion of individual messages from the inbox they are moved into the deleted folder on Outlook.com, the same occurs for the sent items being placed into the sent folder in Outlook.com. I have configured Outlook.com correctly including checking this option "Do what my other program says — if it says to delete messages, then delete them." I have also checked this option in the POP3 section "Do what my other program says — if it says to delete messages, then delete them." I know that I can use the alternate setup to sync the mailboxes with Outlook connector however the processor in this PC is fairly slow and does not handle this method very well. Does anyone know a way under POP3 to clear out the deleted and sent folders using POP3 into the Outlook.com web mail server. I and thousands of others need to resolve this as the web accounts are going to fill up quickly, one should not have to manually go into the web mail account and manually clear these two folders whilst using MS Outlook 2010 or below. NOTE: I also have MS Outlook configured to delete all deleted messages on exit. Any help will be appreciated. Thanks Garry
The deleted items online should clear automatically as the messages age - i think it's as they hit 30 days they are deleted. So as long as they go into the trash online, your mailbox wont fill up due to trash. I thought the mailboxes were fairly large - like 5 GB - so it holds a lot. (I looked in my acct but it doesn't say.)
ETA: sent folders online will need to be cleared online. POP3 only applies to the inbox.
gnbalbion
Hi Dianne, thanks for the prompt reply. In outlook.com there is only a deleted folder, there is no trash folder, I presume that they are the same meaning. My ISP "Bigpond Australia" are using Outlook.com under a special arrangement, our inbox space is 1 GB only. Confirming your reply, when I delete messages from the sent box in MS Outlook, they do not delete from the sent box in Outlook.com. Confirming also, the Sent folder is NOT part of the Outlook.com in box (my 1gb), if so how do I find out the available capacity of the Sent Folder. Thanks....Garry
Yes, Trash is the same as Deleted. Yeah, if you are using POP3, the sent folder is local only, it's not synced. If you se the Outlook connector to connect to the account you'll be able to sync the folders and what you delete in Outlook will be deleted online.
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
UncleBill Unable to delete items from gmail IMAP Trash using Outlook 2010 Outlook VBA and Custom Forms 5
B Outlook 2010: using /altvba switch Using Outlook 1
S Using both My Calendar and iCloud Calendar in Outlook 2010 Using Outlook 4
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
J Outlook 2010 using Quick Print to print attachments Using Outlook 1
T Using Outlook 2010 in Outlook2003 as backup ? Using Outlook 21
N Sending encrypted signed mail using outlook 2010 Using Outlook 1
P Multiple accounts and single Calendar file (Outlook 2010, using Connector) Using Outlook 1
C Deleted email message using Outlook 2010 Using Outlook 2
S Using Multiple Signatures in Outlook 2010 Using Outlook 9
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
M Using Outlook with Yahoo email Using Outlook 6
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
R Using Multiple Accounts in Outlook Using Outlook 3
Diane Poremsky Using Outlook Links Using Outlook 0
Diane Poremsky Using Arrays in Outlook macros Using Outlook 0
Diane Poremsky Using the Outlook Calendar Template Using Outlook 0
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
Diane Poremsky Using Outlook's New Contact Cards Using Outlook 0
Christian Using Outlook's New Contact Cards Using Outlook 4
Diane Poremsky Using Outlook's AutoArchive Feature Using Outlook 0
