Using OR when organising with conditional formatting
adbdkb
Is it possible to use OR ( may be AND, but don't have a use case at the moment ) when defining a condition for Conditional Formatting? For example if I want to create a single rule where I can specify a From Field with UserA OR UserB, apply the following font definition.
I have searched on the net, including this forum but haven't found anything yet.
Or is easy: either use it in the criteria in this format:
From contains userA OR userB
or use two rules:
From contains userA
From contains userB
Tip 49: Creating Advanced Filters | Outlook Tips
Keep in mind that From on the first tab uses the email address, From on advanced tab = display name.
If you are using two different conditions, they are linked by AND.
From contains gmail
To contains Hotmail
The query builder can make it easier to create complex formatting rules. Using Query Builder - Slipstick Systems
- - - Updated - - -
or use two rules:
From contains userA
From contains userB
http://www.outlook-tips.net/tips/tip-49-creating-advanced-filters/
From contains gmail
To contains Hotmail
The query builder can make it easier to create complex formatting rules. http://www.slipstick.com/outlook/using-query-builder/
