Help with Outlook 2007 Macro Please!
Fabio
Can someone please help me with the following:
We have a restaurant with about 500 clients on our email list.
Every now and then we send *.jpeg* adverts for specials, functions etc...
Recently all ISP's here in SA have a limit of 20 email contacts per email ( for Anti SPAM purposes ). However they offer to create a distribution
list for you - at an extra cost and a great inconvenience ( with all the paperwork required ) for small users like us,
and if you need to change addresses you need to send them updated info that they will change in 48 hours....... and and and........
I would like to create, if possible, a Macro in Outlook that would:
1) Create Email
2) Insert Recipient ( 1 email per each and every contact from a distribution list either created in Outlook, Excel or Access )
3) Insert user determined Subject - This might be July Lunch Specials, Themed evening on the 20th... etc
4) Insert a *.jpeg* in the body of the HTML email ( NOT as an attachment )
5) Send! ( with Delivery and Read Receipt )
I would really appreciate if someone could help me with the above
Thanking you in advance
Fabio
Fabio
Thank you very much for replying.
Your idea for a Template is perfect for me.
So what I would like to do is physically create a new mail, type in the subject and insert the advert in the body of the email
Then I would need a Macro to send this mail individually to a distribution list in Outlook that I will have open
Could you please send me a code for this. I have never worked with VBA / Macro before and am learning.
Thank you once again for your great help!
Regards
Fabio
Try creating a message and saving it as a template - then use this macro. You can use the subject field in the template or add the subject in the macro -
Sub Merge_to_Group()
Dim o_list As Object
Dim objMsg As MailItem
' select or open the distribution list
' you need the GetCurrentItem function from
' http://slipstick.me/e8mio
Set o_list = GetCurrentItem()
For i = 1 To o_list.MemberCount
Set objMsg = Application.CreateItemFromTemplate("C:\path\to\test-rule.oft")
With objMsg
 .To = o_list.GetMember(i).Address
 .Subject = "Test Subject"
'  use .display for testing
' .send to send the messages automatically
 .Display
Set objMsg = Nothing
Fabio
thanks very much for your help
it works like a charm!
i introduced a time loop to delay msg sending
by 5 sec intervals
its working really well!
only prob is it comes up as spam :(
even from my own email address..
there's always something wrong
anyways thanks again!
fabio
D Outlook 2007 not working>> Please help tried everything Using Outlook 3
U Need a help please Outlook 2007 crashing Using Outlook 2
P help me plase !!! outlook 2007 I can see mail Bcc Using Outlook 1
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A newb outlook macro help Outlook VBA and Custom Forms 1
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
E Outlook Contacts Help Using Outlook 1
M Outlook Backup help needed ASAP Using Outlook 2
C Please Help outlook 2013 Using Outlook 1
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
E Outlook Tasks Help Using Outlook 6
F Outlook 2010 - Need help with a custom field. Using Outlook 3
K Help Needed - setting up Email in Outlook 2013 Using Outlook 3
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
C Outlook Profile Corrupt...Help!!!!! Using Outlook 0
M HELP! MSN to Outlook Using Outlook 1
A Outlook HELP Using Outlook 1
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
S Desperate for Help with Outlook custom form Using Outlook 0
L Outlook 2013 IMAP account is deleting e-mails from my inbox - help!!! Using Outlook 3
J Outlook 2010 Forms Help Needed "A field in this form requires a value." Using Outlook 6
W I Need help with vb.net and outlook 2010 Using Outlook 2
S Help needed - syncing outlook emails with iphone 4s Using Outlook 4
S Outlook macro help Using Outlook 10
A outlook error Receiving reported error (0x80040900) please help Using Outlook 4
