Force use of general outbox
Robert Jory
Outlook 2013 64 bit
In Outlook 2010 when I clicked send on an email it would go into the general outbox, not the one under the IMAP account. After upgrading to 2013 the email is put in the outbox under the IMAP account. This is a big hassle when I forgot which email account I used to send from and want to double check. I now have to go to each IMAP folder and click it top open and then click on the outbox. I have 10 email accounts so this can be time consuming. is there a way to force all email to send into the general outbox like it use to in 2010.
I have removed the OST file and set the pst file as a default for other reasons and thought this would be a solution but it wasn't
No, now that Outlook supports calendar and contacts in the imap folders, they use their own outboxes. If this is a frequent issue, you can set a reg key so outlook never chooses an account - you'll need to choose the account before sending. See http://www.slipstick.com/outlook/outlook-2010/multiple-accounts-and-the-default-account/ for the reg key.
You can try using instant search - folderpath:eek:utbox and set it to use all mailboxes. Turn off the reading pane and add the account field to the view.
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
J Force account selection for sending reply emails Using Outlook 1
C Force account selection - no reg path nor can create one Using Outlook 9
D How to force full message download for all Gmail messages in all folders with IMAP in Outlook 2013 Using Outlook 1
S Force Outlook to use TCP Using Outlook 1
C Defer email delivery - but when force sent using F9 Using Outlook 1
F force new meetings and appointments to send from my IMAP account Using Outlook 7
A How can I force Outlook 2003 to use A4 paper? Using Outlook 6
J Force the 'From' account Using Outlook 1
F 'General failure (URL) Server execution failed' Using Outlook 1
D a general question regarding data files Using Outlook 3
F General Question Using Outlook 0
A General, how to get started? [kwrds begin start newbie] Outlook VBA and Custom Forms 3
A Note field on general tab BCM (Business Contact Manager) 5
B One email cannot be sent or received (but leaves outbox!) Using Outlook 1
A Cant See outbox items on a secondary Account Exchange Server Administration 3
M Outbox throttler Using Outlook 4
T SMTP messages stuck in Outbox Using Outlook 0
I Outlook 2013 Send mail - it just sticks in Outbox Using Outlook.com accounts in Outlook 0
Diane Poremsky After viewing the Outbox, messages won't send Using Outlook 0
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
M Messages in Outbox reminder is wrong Using Outlook 4
D Use single outbox in Outlook 2013 Using Outlook 1
T Two Outbox's in 2007 but neither send Using Outlook 8
iwshim Transfering mail from the outbox to another computer Using Outlook 0
G "Delay Delivery" Email fails to send if opened while in Outbox Using Outlook 4
F Outbox - Multiple Emails need to be manually opened? Using Outlook 5
B OUTBOX ERROR!!!!! Using Outlook 20
James Emails Stuck In Outlook Outbox Happening Alot Using Outlook 1
Loperman Emails hang in Outbox Using Outlook 1
M some emails send from outbox, some don't Using Outlook 10
S Mystery emails in Outbox Using Outlook 1
J Change Subject of 500 mails sitting in Outbox with Macro Using Outlook 6
B Cannot send emails-stuck in OutBox: OUTLOOK 2013 Using Outlook 4
