Fwd Outlook incomming messages to usb port after Rules and alerts applied
wavrydr239
Since Diane's scripts have been very helpful I will give this a shot. I am a mico programmer and circuit eng but am lost when it comes to VBA and c++. My stuff is in assy code. I have a M2M product using a AVR2560 and sim 900. My problem is with forwarding incoming emails to outlook through the AT&T email to sms gateway due to willy nilly filtering by ATT. I want to create my own gateway and just need a script or whatever it takes to forward an email from a certain phone # (customer) to an sms (my application in the field. The message will be picked up on the USB port. I can massage and filter any kind of format and protocall in hardware and in the micro but need an automated method to simply output the message with envelope (header not necessary) to the usb port. Anything I have found is a packaged product and requires a ton of handshaking. My stuff will synch to any baud rate. Looking even a crumb of info. Thank You
D Outlook 2010 Rules: fwd meeting invitation results in winmail.dat not .ics Using Outlook 4
P AutoForward Randomly Doesn't fwd emails Using Outlook 3
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
