IF AND Validation Formulas in Custom Form
maxwello
I am a Newbie to Outlook Custom Forms and I want to know if it is possible to use a IF AND formula in the validation tab under properties.
What I want to happen is, If the user has selected Bloomberg in the platform field and the Clearing Applicable field is Blank then to throw up a message "Please advise if Clearing is applicable"
I have tried, IF [Platform]="Bloomberg" AND [Clearing Applicable] <> "" and different variations and I have broken it down and tried just using [Clearing Applicable] <> "" which gives me the message but when I tried [Platform]="Bloomberg" nothing worked.
I have searched the internet but haven’t had any luck finding a solution PLEASE HELP.
Appreciative Newbie
maxwello
Thanks Larry,
Although I still cannot get it to work, will the statement work in the Validation Formula bar?
=IIf([Platform]="Bloomberg",[Clearing Applicable] <> "")
Anything available in Fields and Functions should work.
The formula format is IIf( expr , truepart , falsepart ) and it looks like you are missing the falsepart. (I'm not sure the true part is right either)
maxwello
What I want to happen is If Bloomberg = yes then the user needs to put a value in client clearing field, if they dont I need the error message to pop up asking the user to add a value and if Bloomberg isnt selected at all then to ignore everything and carry on.
So far I have entered the formula in the properties validation line and then entered the message in the line below. But with the formulas that I have played around with so far I cannot get anything to work. I would really appreciate some further assisance as this is stopping me getting any further on my project.
Kind Regards
OLiver
B Date validation in Outlook Custom Form Using Outlook 2
C Forms: Validation Using Outlook 0
C Outlook Forms: Validation Using Outlook 7
S Reminder Time and Reminder Validation Outlook VBA and Custom Forms 2
F Data validation Outlook VBA and Custom Forms 4
C Adding date Validation between 2 months Outlook VBA and Custom Forms 3
C date formulas / mathematics, setting a field one hour past another field value Outlook VBA and Custom Forms 1
J ol2021 custom form not displaying pics Outlook VBA and Custom Forms 30
N "Perform a Custom Action" Outlook VBA and Custom Forms 0
E Custom formula for columns Using Outlook 3
