Advanced find query facilty Help please
artincanada
Outlook 2013 64 bit
I am looking to perform and 'and' or an "or" to a search or a rule
HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\<version>\Outlook\
I went to this key to add a new key called querybuilder (from an article) is seems in Windows 7 Outlook 2010 there is no such key address.. can you tell me if this registry change direction and change still works and how. This give a query builder in advanced search so i beleive
Art
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
O Advanced search - can I use booleans Using Outlook 3
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
A Outlook Advanced Search Problems...returns with an Error: Argument Outlook VBA and Custom Forms 1
J Advanced outlook trick: help needed! Outlook VBA and Custom Forms 3
T Outlook 2007 Indexing Options and Advanced Search options disabled Using Outlook 5
J search doesn't find anything Using Outlook 1
M Issues with templates - unable to find in old web app Using Outlook 3
witzker How to find all emails from and to a contact in OL 2019 Using Outlook 6
M How can we find the list of users who are members of a deleted distribution list? Exchange Server Administration 2
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
C Find all deleted recurrence appointments Outlook VBA and Custom Forms 4
