email folders appear empty, at first click
astro46
Outlook 2016 64 bit
this has been happening for several months, OL13. I click on email Inbox, or a sub folder, and it appears empty, no email shown. I have to click on another folder and then back to that folder, to get the email to appear. doesn't happen every time. but occasionally.
anyone else experience this? any possible fix?
This is happening with a pop3 account? Try resetting the view on a folder and see if it helps. If not, I'd probably use scanpst on the data file and see if that fixes it.
Sometimes resetting the view on a folder isn't enough and you need to clean out all views using the cleanviews switch. I always hesitate to recommend this as a first step because it wipes out all custom views. If you don't use custom views, then it doesn't matter and you can use it first.
Close Outlook, then click Windows key+R to open the Run command), type or paste
outlook.exe /cleanviews
and press enter. Note, there is a space between outlook.exe and the /.
astro46
Outlook 2016 64 bit
there a number of pop3 accounts, but I doubt that it has anything to do with the issue. some of the folders contain email that is dragged to them after reading.
I tried scanpst, it claims to have found and repaired an error, so time will tell if problem reappears.
and yes, I am reluctant to delete custom views. especially since it is not known if this will fix it. I can try resetting the view if problem reappears.
thanks.
cimbian Harvesting email addresses from mail folders Using Outlook 1
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
Diane Poremsky Create Tasks from Email and move to different Task folders Using Outlook 0
D How to copy yahoo email folders to hard drive Using Outlook 2
T outlook 2010 email folders Using Outlook 5
L Can't share email folders Exchange Server Administration 1
M Outlook 2013 folders - don't want to synchronize with email provider's server Using Outlook 15
B Is there a simple way to share email folders w/o exchange server? Using Outlook 0
T I recently changed my pop3 email to an imap - question on folders Using Outlook 3
K Missing email from Outlook Folders Using Outlook 2
M Access replicated Outlook (email folders, calendar, contacts, notes) via web Using Outlook 1
S Wrong email account displayed in folders Using Outlook 3
D User cannot move email messages within Outlook Inbox folder and sub-folders. Using Outlook 0
H How do I import all my old email from Entourage 2004 (I have put email in separated folders), into my smart box of Outlook 2011 ? Thanks__ Using Outlook 2
H Not all Email folders appearing in Manage E-mail Auto-linking BCM (Business Contact Manager) 1
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
C Email bomb processing Outlook VBA and Custom Forms 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
G Place jpg in body of email Outlook VBA and Custom Forms 1
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 12
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 5
G Email time stamp Using Outlook 2
