Send mail and contents of body from ms word document
zmagic
Outlook 2013 32 bit
I send mail with this script and the contents of body are cell values, now i want to add the contents from ms word which is in "c:\Email Contents\covering.doc". Please some guide me doing this.
   Option Explicit
   Sub Send_Files()
   Dim OutApp As Outlook.Application
   Dim OutMail As Outlook.MailItem
   Dim sh As Worksheet
   Dim cell As Range
   Dim FileCell As Range
   Dim rng As Range
   With Application
       .EnableEvents = False
       .ScreenUpdating = False
   Set sh = Sheets("sendemail")
   Set OutApp = CreateObject("Outlook.Application")
       For Each cell In sh.Columns("G").Cells.SpecialCells(xlCellTypeConstants)
       'Enter the path/file names in the C:Z column in each row
       Set rng = sh.Cells(cell.Row, 1).Range("K1:Z1")
       If cell.Value Like "?*@?*.?*" And _
       LCase(Cells(cell.Row, "H").Value) = "yes" _
       And LCase(Cells(cell.Row, "I").Value) <> "send" And _
       Application.WorksheetFunction.CountA(rng) > 0 Then
          Set OutMail = OutApp.CreateItem(olMailItem)
       With OutMail
       .To = cell.Value
       '.CC = ""
       .Subject = "Reports & Statements "
       .Body = "Dear Sir / Madam," & vbNewLine & vbNewLine & _
               "Status : " & cell.Offset(0, 3).Value _
               "Report No.: " & cell.Offset(0, -5).Value _
 [U][B]Get Contents from .doc file
[/B][/U]
               For Each FileCell In rng.SpecialCells(xlCellTypeConstants)
                   If Trim(FileCell) <> "" Then
                       If Dir(FileCell.Value) <> "" Then
                           .Attachments.Add FileCell.Value
               Next FileCell
              '.Send
               .Display  'Or use Send
On Error GoTo 0
Cells(cell.Row, "I").Value = "send"
           Set OutMail = Nothing
   Next cell
cleanup:
   Set OutApp = Nothing
   With Application
       .EnableEvents = True
       .ScreenUpdating = True
Have you seen the macro at http://www.outlookcode.com/codedetail.aspx?id=1333 ? That should do what you want to do - it uses the wordmail envelope for the message rather than reading the document and pasting it into the message.
It should work in all versions of outlook.
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
I Outlook 2013 Send mail - it just sticks in Outbox Using Outlook.com accounts in Outlook 0
Tim King Send mail from MSWord through Outlook Using Outlook 3
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
R Unable to send mail using Cox.net Using Outlook 1
Emerogork How do I activate the "Send Again" option in Sent Mail folder? Using Outlook 1
S Check if two organisition is added then i have to give managers passward creteria to send mail Using Outlook 1
A Application_ItemSend not accessed when sending email outside outlook (i.e. word or send to mail from Using Outlook 7
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
A yahoo mail doesn't send or receive reliably Using Outlook 1
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
C Insert a Date Picker for Send Mail Subject Using Outlook 1
C MsgBox Everytime I send a mail Using Outlook 1
L "sometimes" cant send mail, we have to copy and paste the message and resend? Using Outlook 2
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
L Send E-mail with VBA code from [E-mail Distribution Group] if I have “Send as” Using Outlook 6
S Outllok 2007 VBA code to send mail automatically from drafts folder Using Outlook 1
A How to send Personalized attachment while sending mass mail Using Outlook 1
G Rule: IF mail received by X, THEN no action; IF mail not received by X, SEND Using Outlook 0
E Outlook cannot connect to your incoming (POP3) e-mail server/Cannot send mess. Using Outlook 0
T HELP - Send e-mail verification text box Using Outlook.com accounts in Outlook 10
B How do I create and send mail in Outlook 2003 from code? Using Outlook 5
J Outlook 2003 does not send or receive imap mail from server Using Outlook 0
R OL10 - Send To "Mail Recipient" doesn't go to default email account Using Outlook 23
O Send Mail Via Outlook Even If Outlook Is Closed Using Outlook 4
C send mail every days Outlook VBA and Custom Forms 7
D How can I send a group email to a color catagory re: yellow= mail BCM (Business Contact Manager) 1
T Get rid of having to type verification characters to send mail BCM (Business Contact Manager) 2
H how to send a e-mail with a annex automaticly Outlook VBA and Custom Forms 3
D Outlook 2007 Will Not Send Mail From C# Application Outlook VBA and Custom Forms 7
P Move mail item after send Outlook VBA and Custom Forms 2
G Send Mail If Statement Outlook VBA and Custom Forms 4
Q Error code appears when I try to send e mail Using Outlook 2
