Outlook Locks up After Sitting Idle
kthack
When switching from a PC with Windows 7 to a new PC with Windows 8.1 pretty much everything went smoothly except moving Outlook 2010. O M G ! ! This has been SO frustrating.
Thanks to what I've read on your site, I created a new profile. It worked fine for about a day then it started giving the aggravating "access denied" error. I noticed that it only does this after it sit idle for a while. After I get that error, I have to completely reboot my computer to get Outlook working again.
Any ideas on how to fix this? Should I go in a delete the old profile? Do you think it's still causing issues?
What addins do you use? Antivirus? Backup software? It sounds more like something to hooking into the pst when outlook is idle.
Try running outlook in safe mode and see if you get the same error. If not, it's like any addin.
Wayne Outlook locks up when opening "Manage Rules & Alerts" Using Outlook 7
B Outlook 2003 locks me out of virtual machine Using Outlook 1
J Outlook 2010 messages freeze in outbox, do not autosave, then disappear after Outlook locks up Using Outlook 7
P Contact Manger locks up Outlook when I click on folder? BCM (Business Contact Manager) 2
U Outlook 2019 VBA run-time error 424 Outlook VBA and Custom Forms 1
K Outlook 2019 Randomly Disconnecting from Gmail Servers Using Outlook 5
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 2
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 3
S Mac Outlook 365 Questions Using Outlook 0
M Outlook calendar is missing Using Outlook 2
T Have you written an articles about Outlook? Using Outlook 3
V Compound IF, OR, AND in Outlook form Outlook VBA and Custom Forms 4
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
R Outlook 365 update sets delete from server flag Using Outlook 1
X Outlook automation pull from PDF Using Outlook 5
O Outlook 365 - How to create / copy a new contact from an existing one? Using Outlook 3
M Gmail address associated with Outlook on new phone Using Outlook 9
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
V Validating Outlook form with "OR" and "AND" Outlook VBA and Custom Forms 1
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
V Outlook behaving oddly Using Outlook 2
M HTML email signature in Outlook Using Outlook 1
M Respond to Outlook Email Outlook VBA and Custom Forms 0
U Outlook locking up when replying to Email Using Outlook 7
J Outlook Autocomplete (Recipients) opens upward Using Outlook 2
P Syncing Outlook & iPhone Calendars Using Outlook 4
S Unable to extract text from an Outlook email message Using Outlook 2
O Outlook on Android: after sharing / sending a news article, draft remains open. Why? Using Outlook 1
F Outlook 365 is "Possessed" Using Outlook 2
