Outlook 2013 using DAMO (connector for Domino) Sent Items Issue
OL4
Outlook 2013 32 bit
I'm using Outlook 2013 to connect to a Domino server (8.5.3FP5) using DAMO.
Everything appears to be working properly, except when I send email through Outlook. The email is sent & appears in (Outlook) Sent Items, but does not sync with the server. In other words, I will not see it in the Sent "View" of Lotus Notes, nor on my iPhone where I use Lotus Traveler (which uses the iOS built in email client).
If I send an email through Notes or the Phone, I will see those messages saved properly on all clients (Outlook included).
This situation make it impossible to use Outlook for sending email (as the sent items is not synched properly across clients).
Can you please help with a solution for this?
Thanks a lot!
Ron
It sounds like DAMO is not syncing the sent folder. This has been a problem for years (since at least Outook 2007's release, if not earlier) One possible fix is to add the following line to the notes.ini (usually at C:\Program Files\DominoForOutlook)
REPL_PST_FORCE_SUBMIT=1
It works for some people but not others. Otherwise, I'm not aware of a fix - DAMO is no longer in development and won't be fixed.
OL4
Outlook 2013 32 bit
Appreciate the response Diane, I'll give it a shot.
Thanks for all the work you do.
Regards,
Ron
C search outlook 2013 folder using keyword identifiers Using Outlook 1
P IM and Phone icon is Grayed out in Outlook 2013 - Using Lync 2013 Using Outlook 4
D Using Libraries when inserting a file in Outlook 2013 Using Outlook 1
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
J Outlook 2013 and outlook.com issues when using mail alias Using Outlook.com accounts in Outlook 2
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
M using Outlook 2013 search Using Outlook 3
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
A Outlook 2013 IMAP using Google Mail App not syching Sent Mail Using Outlook 3
P Sync 2013 calendar between 2 devices -Surface 2 and Desktop using Outlook.com Using Outlook.com accounts in Outlook 8
V Using Outlook 2013 Off Line Using Outlook 5
V using Bcc in Outlook.com 2013 Using Outlook 1
R Folders shifting around in Outlook 2013 and 2016 Using Outlook 3
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
