Create additional custom flag descriptions (other than Send E-Mail, Call etc.)
David J.
The existing custom flags are limited to: "Follow Up, Call, Arrange Meeting, Send email, Send Letter". How can I create more (or change current) options here? I can type a new one at any time, but I am constantly typing the same ones repeatedly, and not using the defaults. (Nor is one I type in custom saved to be used the next time - this would be sufficient, too.)
C Can't create Outlook data file Outlook Wishlist 0
Diane Poremsky Create a Task when a Message is Flagged Using Outlook 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
Diane Poremsky Automatically create a task when sending a message Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
