Downgrade from Outlook 2013 to Outlook 2010
tt-hg
Outlook 2013 32 bit
I am currently using Outlook 2013 (non-Exchange environment), but will be switching computers to one running Outlook 2010. Is the .PST file from Outlook 2013 compatible with 2010, or is there some kind of conversion necessary to make sure all data is transferred? Thanks in advance.
MiniMe
Outlook 2013 64 bit
In what way? do you have any error messages?
Kashan Zaman
Outlook 2013 32 bit
Not any error but when i make rule its working fine but after 48 hours or sometime 24 hours its not working ,
MiniMe
Outlook 2013 64 bit
Is it disabled in Rules & alerts or just stops working? How does the rule read?
Kashan Zaman
Outlook 2013 32 bit
just stop , rule is working fine but stop working after 48 hours or sometime 24 hours , i did re-create then its working fine , only 12 or 13 rule i have
Diane Poremsky Office 365 (Office 2016) Downgrade Rights Using Outlook 0
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 0
@ Outlook Using Outlook 2
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
