Sync Business contacts with Icloud contacts
Outlook 2013 64 bit
Good morning,
Thank you for your help.
I am trying to sync the bcm contacts with the icloud contacts. On the sync page instead of using a normal pst i choose on the icloud section the contacts folder.
It accepts but nothing happens and so nothing is synched...
Thank you very muech for your help.
All the best
Pedro Pimenta
cldom
Outlook 2013 64 bit
BCM Contacts and iCloud Contacts are usually stored in separate PST files in Outlook. The key is to synchronize the BCM PST data to the iCloud PST.
I'm unsure if BCM has a built-in tool to do this.
CompanionLink is 3rd-party software that can be set up to synchronize BCM with iCloud.
O Outlook 2016 - two addressbooks - how to sync and which one is in use? Using Outlook.com accounts in Outlook 1
Peter R Hawkes Can I sync VBAProject.otm? Outlook VBA and Custom Forms 1
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
M Mobile notifications and sync in Outlook.com Using Outlook.com accounts in Outlook 2
GregS No contacts sync from Outlook 2016 to Windows Phone Using Outlook 0
GregS Sync contacts Outlook.com to "MS People" mobile Using Outlook 1
Diane Poremsky Outlook Connector Contact Sync Bug (Fixed) Using Outlook 0
H Sync Contacts between Office 365 and Gmail. Exchange Server Administration 3
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
S Outlook 2016 Sync issues with outlook.com Using Outlook 0
