Use same BCM data in 2 offices
andyga
Hello
I have 1 office in Germany and 1 in Italy
In Germany my BCM works with 2 PCs ok. Now I want to use the same data also in Italy
How is this possible? I tried to backup in Germany and restore in Italy but I could not restore becaude I am not the owner of the database. In Germany there is another user the owner of the DB.
Is it possible to sync the data?
Then: Here in Italy I also want to use a laptop with the same data. Can I sync this also?
and also a Nokia Lumia 1520 (at least the contacts)
BTW: It has not to be a real sync. I only want to use the same initial data. it has not to sync all calender and every day - only once. to have the same database
if dayly sync is possible - it's better but not neccessary
andyga
you are great!
can you tell me also how to sync outlook with BCM?
I tried it once with the BCM function "synchronizie with outlook" but then I had all the contacts twice
In the BCM is also written "(i) the companycontacts will not be syncronized with the outlook contacts"
but I need all the contacts in outlook to sync the with my Nokia phone, don't I?
or is it possible to sync the Nokia phone with BCM?
That would be the way to do it. I dont know why you got the duplicates. If you need the company contacts, you need to copy them to the contacts folder . you can select all, copy then paste.
O Same email address, same person, names in so many ways Using Outlook 4
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
A Two Inboxes, Same Email? Using Outlook 3
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
N Move emails of same conversation to same subfolder Using Outlook 6
I get count of all emails with same conversation ID Outlook VBA and Custom Forms 2
R Shortcut for attaching the same file repeatedly Using Outlook 6
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
C How to copy same text header to multiple emails with custom text column Using Outlook 10
D Calendar - color coded items are now the same color Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
B Mail on both laptop and mobile at same time Using Outlook 2
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
L Delete code and commandbutton at the same time. Using Outlook 1
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
L IMAP and POP email in same Outlook system Using Outlook 1
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
S Searching contacts across GAL and local address book at same time Using Outlook 1
D Move email to same folder as the rest of the conversation Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
R View two Inboxfolders at the same time in split creen Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
D ActivitiesTab in OL2000 - same functionality in OL2013? Using Outlook 1
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
Z Keep Unread Messages in same folder Using Outlook 2
D Multiple Users Updating Custom Form At Same Time Using Outlook 1
K Save a received email in a mailbox subfolder which is the same as the @email Using Outlook 1
Commodore Renamed folder staying at the same position Using Outlook 3
E "Current View" settings across multiple users on same Exchange 2007 account. Using Outlook 1
A In Contacts Phone List View, allow alpha jump w/single key, same as Card views Using Outlook 4
P Different names for the same email address Using Outlook 1
L HOw to get rid of multiple recurrent appointments that are all the same Using Outlook 1
K Need to get OOO messages more than once for the same email box Using Outlook 2
P Two occurrences of "Appoint name" cannot occur on the same day Using Outlook 3
Rupert Dragwater How to highlight lists of same e-mail Using Outlook 2
