In email, tab sequence and Shift-S for send
astro46
Outlook 2016 64 bit
Does anyone know what the tab sequence is when writing email? I know that tab moves the cursor from To:, to Cc:, to Bcc: to subject. Where is the cursor going when hitting Tab after that. Hitting tab again goes to content field, but where is the cursor going between Subject and Content?
I ask because it seems like the cursor used to go straight from Subject to Content. Now it disappears (at least I can't figure out where it is going) for one Tab click. Moreover, hitting Shift-S while it is in disappear, the email sends. I can't find any references to Shift-S being a hotkey for sending email. And it only happens in that state between Subject and Content.
Weird. Though, of course, not the only weirdness in Outlook.
Jeffrey
astro46
Outlook 2016 64 bit
You'll think I am crazy, but I just tried sending an email to myself, (as I did yesterday when determining that shift-s was doing the sending), just to reconfirm the Shift-S behavior, and found that the tab sequence is now working correctly: Tab takes me from Subject to Body.
For a couple of weeks, through yesterday, this was the behavior. Not today.
Really.
I have no idea what was happening.
Did you reboot? Do you always reboot? If you don't always reboot, something running in the background could have done something to make it behave weirdly. Or it could be caused by a program you use frequently but haven't used yet today.
astro46
Outlook 2016 64 bit
I reboot at least once a day.
I will keep the "running in background" idea in mind, investigate if it should happen again.
thanks for the suggestion.
Jeffrey
S Customing tab order in email template Outlook VBA and Custom Forms 1
B Search and Find Email by Folder Name Outlook VBA and Custom Forms 0
C Email bomb processing Outlook VBA and Custom Forms 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
G Place jpg in body of email Outlook VBA and Custom Forms 1
F Wishlist Outlook suddenly began synchronizing deleted items every time I delete a single email. Using Outlook 2
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 12
F Email being marked as Spam by Gmail and not being visible in Outlook Using Outlook 5
G Email time stamp Using Outlook 2
K Multiple Rules on Single Email Using Outlook 2
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
O Same email address, same person, names in so many ways Using Outlook 4
K Outlook adds space to rows in HTML email signatures viewed on mobile Using Outlook 1
M HTML email signature in Outlook Using Outlook 3
M Respond to Outlook Email Outlook VBA and Custom Forms 0
U Outlook locking up when replying to Email Using Outlook 7
S Email Generated from another program and then edited sends original email. Using Outlook 2
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P How did hacker cause link to delete and archive containing email? Using Outlook 6
I 'quote marks' around email name Using Outlook 1
