Paragraph formatting in blank messages/stationery
Copwriter
Outlook 2013 64 bit
In composing new email messages and replies in Outlook 2013 (and other versions as well), I prefer to have a six-point space between paragraphs. I can do this when I am done composing the mesage or reply by selecting all the text and applying the desired paragraph formatting, but I would prefer it be done by default. I've found the settings in Options to select the font and font color (and other font characteristics) for messages, and to create signature blocks, but none for paragraph formatting. Is there a setting I am missing here?
clark kent
Hi Friend,
In Outlook 2013, you can change the default spacing of paragraph by following the given steps:
New Email >> Format Text >> Change Styles >> Paragraph Spacing >> Custom Paragraph Spacing
In “Custom Paragraph Spacing” option, you can apply the required spacing according to requirement.
Hope it will work!!!!!
Note: Select the "New documents based on this template"option also.
Clark Kent
Copwriter
Outlook 2013 64 bit
That did it! Thanks much for your quick and very helpful reply.
M Outlook 2016 IOS recipients receive my paragraph double space as quadruple space Using Outlook 2
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
V Can one change the formatting of email title blocks? Using Outlook 0
K Outlook tasks formatting Using Outlook 4
E Conditional formatting - when current account <> received account ? Using Outlook 3
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
S Conditional Formatting in calendar part of To-Do Bar Using Outlook 1
K Conditional Formatting based on Department of person received from? Outlook VBA and Custom Forms 4
L Email to task without changin formatting Outlook VBA and Custom Forms 16
C Change default colors for conditional formatting Using Outlook 2
Diane Poremsky Use Word Macro to Apply Formatting to Email Using Outlook 0
D Outlook 2007 Formatting Using Outlook 1
D telephone formatting Contacts Using Outlook 2
D Conditional formatting - font sizes Using Outlook 3
A Lync meeting in outlook lose HTML formatting Using Outlook 3
A Help creating macro for conditional formatting settings Using Outlook 8
B Conditional Formatting:How to use >1 value in a filter Using Outlook 7
V Report stuck formatting page Using Outlook 1
T The Formatting Changes When A Recurring Appointment is Changed Using Outlook 1
J Formatting Contacts to Export for iPhone Using Outlook 0
O How do I get rid of odd formatting of new e-mails? Using Outlook 3
A Using OR when organising with conditional formatting Using Outlook 1
G Outlook 2010 not formatting in-line comments Using Outlook 5
J Conditional Formatting Upon My Reply Using Outlook 1
Commodore Auto-formatting of certain phone numbers Using Outlook 2
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
E Email Formatting - Tabs Using Outlook 1
A Need method to rapidly correct telephone contact telephone number formatting Using Outlook 1
N lose conditional formatting when importing to Outlook 2010 Using Outlook 2
H Formatting of email conversation print outs - URGENT Using Outlook 1
K Problems with message formatting for individual user Using Outlook 1
M Auto-correct Contact fields' formatting? Using Outlook 7
O Hyperlink formatting lost after replacement in outlook Using Outlook 5
O Hyperlink formatting lost after replacement in outlook Using Outlook 0
D Formatting Styles when Replying Using Outlook 10
K Outlook 2010 conditional formatting Using Outlook 21
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
W Formatting Outlook VBA and Custom Forms 1
H C# inserting word document with formatting into outlook message Outlook VBA and Custom Forms 1
